[SOLVED] DS3231 uRTC set / read problems
raspi3ua
Re: [SOLVED] DS3231 uRTC set / read problems
Post by raspi3ua » Thu May 11, 2017 1:59 pm
I have the same problem with Alarm.
DS3231 RTC connected to NodeMCU v3.
>>> import urtc
>>> from machine import I2C, Pin
>>> i2c = I2C(scl=Pin(5), sda=Pin(4))
>>> rtc = urtc.DS3231(i2c)
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=11, weekday=4, hour=16, minute=42, second=37, millisecond=None)
>>> rtc.alarm_time((None,None,11,None,16,55))
>>> rtc.alarm_time()
DateTimeTuple(year=None, month=None, day=11, weekday=None, hour=16, minute=55, second=None, millisecond=None)
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=11, weekday=4, hour=16, minute=53, second=38, millisecond=None)
>>> rtc.alarm()
False
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=11, weekday=4, hour=16, minute=56, second=38, millisecond=None)
>>> rtc.alarm()
False
Post by deshipu » Thu May 11, 2017 3:16 pm
Make sure you have the latest version of the library. There were some more bugs fixed.
raspi3ua
Post by raspi3ua » Fri May 12, 2017 6:21 am
deshipu wrote:Make sure you have the latest version of the library. There were some more bugs fixed.
Download 1.2 version of library from https://github.com/adafruit/Adafruit-uRTC/releases.
Current situation:
>>> i2c.scan()
[64, 104, 112]
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=12, weekday=5, hour=9, minute=10, second=8, millisecond=0)
>>> rtc.alarm_time((None,None,12,None,9,17))
>>> rtc.alarm_time()
  File "urtc.py", line 93, in alarm_time
AttributeError: 'I2C' object has no attribute 'redfrom_mem_into'
>>> rtc.alarm()
False
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=12, weekday=5, hour=9, minute=27, second=14, millisecond=0)
>>> rtc.alarm()
False
Post by deshipu » Fri May 12, 2017 8:14 am
Can you try with the master?
Also, please use the I2C object from machine, not from pyb.
raspi3ua
Post by raspi3ua » Fri May 12, 2017 8:39 am
deshipu wrote:Can you try with the master?
Use Library master.
MicroPython v1.8.7-7-gb5a1a20a3 on 2017-01-09; ESP module with ESP8266
>>> import urtc
>>> i2c.scan()
[104]
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=12, weekday=5, hour=11, minute=32, second=50, millisecond=None)
>>> rtc.alarm_time((None,None,12,None,11,34))
>>> rtc.alarm_time()
DateTimeTuple(year=None, month=None, day=12, weekday=None, hour=11, minute=34, second=None, millisecond=None)
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=12, weekday=5, hour=11, minute=33, second=19, millisecond=None)
>>> rtc.alarm()
False
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=12, weekday=5, hour=11, minute=35, second=8, millisecond=None)
>>> rtc.alarm()
False
Use Library ver2.
>>> import urtc
>>> i2c.scan()
[104]
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=12, weekday=5, hour=11, minute=28, second=58, millisecond=0)
>>> rtc.alarm_time((None,None,12,None,11,30))
>>> rtc.alarm_time()
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=12, weekday=5, hour=11, minute=29, second=50, millisecond=0)
>>> rtc.alarm()
False
>>> rtc.datetime()
DateTimeTuple(year=2017, month=5, day=12, weekday=5, hour=11, minute=31, second=0, millisecond=0)
>>> rtc.alarm()
False
Post by deshipu » Fri May 12, 2017 11:40 am
I will try to look into it in the evening. There must be one more bug left there. Sorry for that, I didn't test that particular chip very well.
vahithosan
Post by vahithosan » Wed Jul 26, 2017 5:34 pm
Hi. I have nodemcu v3 and DS3231 rtc. I want to use external rtc for high accuracy. And I want to awaken the ESP8266 from sleep with this rtc. I connected the RTC's SQW to reset terminal of the ESP8266. But nothing is happening.
I use urtc on 1.9.1 firmware
[code]
import utime
import urtc
import network, time
from ntptime import settime
sta_if.active(True)
sta_if.connect('SSID', 'passwd')
sta_if.ifconfig()
settime() # ntp
tampon1=utime.time() # for convert to second
tampon2=tampon1+10800 # for gmt+3
datetime = urtc.seconds2tuple(tampon2)
rtc.datetime(datetime)
rtc.datetime()
rtc.alarm_time((None,None,datetime.day,None,datetime.hour,datetime.minute+1,0)) # Alarm after a minute
rtc.alarm_time()
machine.deepsleep()
[/code]
vahithosan
Post by vahithosan » Sat Aug 05, 2017 10:40 pm
I am confused when working with ds3231. I dont understand how the alarm works. I want an alarm every minute.
I can not see changes in 0E and 0F.
[code]
import utime
import urtc
import ustruct
sta_if.active(True)
sta_if.connect('SSID', 'PASSWD')
sta_if.ifconfig()
settime()
rtc.datetime()
rtc.alarm_time((None,None,None,None,None,None,55))
[/code]
[code]
def liste():
s=rtc.datetime()
al=rtc.alarm_time()
print("Time : ",s.year,s.month,s.day,s.hour,s.minute,s.second,sep=" | ")
print("Alarm : ",s.year,s.month,s.day,s.hour,s.minute,al.second,sep=" | ")
print("Is alarm set ? ",rtc.alarm())
print("#"*36)
for i in range(0,19):
a = i2c.readfrom_mem(104,i,1)
b = ustruct.unpack('<h',a)
c = '{:08b}'.format(b[0])
print("{:0{}x}".format(i,2),c[0],c[1],c[2],c[3],c[4],c[5],c[6],c[7],sep=" | ",end="")
print(" | ")
print("-"*36)
return
[/code]
>>> liste()
Time : | 2017 | 8 | 6 | 1 | 19 | 34
Alarm : | 2017 | 8 | 6 | 1 | 19 | 55
Is alarm set ? True
0e | 0 | 0 | 0 | 1 | 1 | 1 | 0 | 0 |
0f | 0 | 0 | 0 | 0 | 1 | 0 | 1 | 1 |
>>> liste()
Time : | 2017 | 8 | 6 | 1 | 19 | 55
Is alarm set ? True
>>> liste()
Time : | 2017 | 8 | 6 | 1 | 19 | 56
Is alarm set ? True
Thanks.
Post by deshipu » Sun Aug 06, 2017 9:13 am
I guess there is still a bug in the DS3231 alarm handling in that library, but I can't figure out what could possibly be wrong.
vahithosan
Post by vahithosan » Sun Aug 06, 2017 5:56 pm
deshipu wrote:I guess there is still a bug in the DS3231 alarm handling in that library, but I can't figure out what could possibly be wrong.
Thanks for your efforts.
I think there are 3 conditions for alarm activation.
INTCN==1 and
A1IE==1 and
A1F==1
A1F is 1 when the time and alarm match
For A1IE;
At first 0x0E register has 0x1c value. (No Time, No Alarm)
0x0E register must be 0x1d when alarm is set. But 0x0E content (0x1c) does not change when alarm is set
According to my opinion
If the value of the control register changes to 0x1d when the alarm is set, the alarm will run.
