boot.py static ip configuration
Posted: Wed Jan 25, 2017 10:17 pm
I'm building a static ip configuration from the Wipy tutorial. But I'm using a WemosD1mini
when restarting I get the error.
Though the Wipy code states.
Do I need to change this for Wemos?
File "boot.py", line 16, in <module>
AttributeError: 'WLAN' object has no attribute 'init'
from network import WLAN
wlan = WLAN() # get current object, without changing the mode
if machine.reset_cause() != machine.SOFT_RESET:
wlan.init(WLAN.STA)
# configuration below MUST match your home router settings!!
wlan.ifconfig(config=('192.168.178.107', '255.255.255.0', '192.168.178.1', '8.8.8.8'))
if not wlan.isconnected():
# change the line below to match your network ssid, security and password
wlan.connect('mywifi', auth=(WLAN.WPA2, 'mywifikey'), timeout=5000)
while not wlan.isconnected():
machine.idle() # save power while waiting
