1.8.7 fails to install
klankschap
Post by klankschap » Sat Jan 28, 2017 1:24 pm
i tried to flash the latest 1.8.7 firmware into the esp8266 nodemcu amica
however it will result in continuous text dump on the screen.
version 1.8.6 gives similar results
version 1.8.4 does work.
How to proceed?
.F
Mike Teachman
Re: 1.8.7 fails to install
Post by Mike Teachman » Sat Jan 28, 2017 3:14 pm
Based on your observations I think this post might help you:
viewtopic.php?f=16&t=2625&hilit=flash+size+esptool
I suggest also to flash with 115200 BAUD
Here is how I use esptool to flash micropython
esptool.py --port COMx erase_flash
esptool.py --port COMx --baud 115200 write_flash 0 esp8266-20161110-v1.8.6.bin
klankschap
Post by klankschap » Sat Jan 28, 2017 3:30 pm
that did not solve the problem:
ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l`�nnl`nr���nl`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��`p�n�r�������bn�|�b��nn�l`�nnl`nr���n�l�lr��n�l�l�r���nb�nl�|��n|pl�|n��⒂b�n`rll��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b��ll`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|���b��nn�l��l
my espwrite settings are:
#!/usr/bin/env bash
python2 esptool.py -p /dev/tty.SLAB_USBtoUART erase_flash
python2 esptool.py -p /dev/tty.SLAB_USBtoUART --baud 460800 write_flash --flash_size=8m -fm dio 0 $@
and changing it into:
#!/usr/bin/env bash
python2 esptool.py -p /dev/tty.SLAB_USBtoUART --baud 115200 write_flash 0 $@
did not help
It works fine with firmware version 1.8.4
.F
jwissing
Post by jwissing » Wed Feb 08, 2017 5:07 pm
I had the same issue when trying to burn the latest firmware to a new Amica nodeMCU board.
Adding -fm dio to the write_flash did help.
esptool.py --port /dev/ttyUSB0 erase_flash
esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash -fm dio 0 ../esp8266-20170208-v1.8.7-205-g181f7d1.bin
klankschap
Post by klankschap » Wed Feb 08, 2017 5:15 pm
the -fm option was in my original script.
did not work
.F
jwissing
Post by jwissing » Thu Feb 09, 2017 6:01 am
This is reproducable.
After flashing without -fm dio:
Fatal exception (28):
epc1=0x4000228b, epc2=0x00000000, epc3=0x00000000, excvaddr=0x000000b5, depc=0x00000000
000000
The firmware is in this exception loop.
After flashing with -fm dio a get a normal prompt:
MicroPython v1.8.7-205-g181f7d1 on 2017-02-09; ESP module with ESP8266
BTW. I don't know what -fm dio actually is doing.
klankschap
Post by klankschap » Thu Feb 09, 2017 9:36 am
with espwritex defined as:
#!/usr/bin/env bash
python2 esptool.py -p /dev/tty.SLAB_USBtoUART --baud 115200 write_flash --flash_size=8m -fm dio 0 $@
then then flashing the esp8266:
$ ./espwritex esp8266-20170209-v1.8.7-205-g181f7d1.bin
Namespace(baud=460800, operation='erase_flash', port='/dev/tty.SLAB_USBtoUART')
Connecting...
Namespace(addr_filename=[(0, <open file 'esp8266-20170209-v1.8.7-205-g181f7d1.bin', mode 'rb' at 0x104046d20>)], baud=115200, flash_freq='40m', flash_mode='dio', flash_size='8m', operation='write_flash', port='/dev/tty.SLAB_USBtoUART', verify=False)
Connecting...
Erasing flash...
Took 8.34s to erase flash block
Wrote 573440 bytes at 0x00000000 in 56.2 seconds (81.6 kbit/s)...
Leaving...
then reset the unit
The blue led goes blinking at a high speed.
Then connect:
$ screen /dev/tty.SLAB_USBtoUART 115200
The screen fills up:
���bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn�llll�b���`rll��|�l�|�l�b|����r�b�b��nn�lnn���bp��lrlrlp�n��lbn�|�l�b��nn�l��l`�nnl`nr���nrll`p�n�r�����bn�|lb��nn�l`�nnl`nr���n��lp�n�r�������bn�|�b��nn�l`�nnl`nr���n�bl`r��n�bl`�l��|��rrnb��l�b�lb쌜���lb�lrl���p�nn
again, version v1.84 does flash correctly, but beyond that it doesn't...
How to proceed ?
.F
jwissing
Post by jwissing » Thu Feb 09, 2017 11:53 am
Is it possible that erase and flash overlap?
klankschap
Post by klankschap » Thu Feb 09, 2017 11:55 am
i don't know
how to check ?
i have two esp8266 and they behave identical.
they work with v1.8.4 but not 1.8.7
jwissing
Post by jwissing » Thu Feb 09, 2017 5:42 pm
I can somehow reproduce your problem when flashing with --flash_size=8m on a 4MB board.
When i flash with --flash_size=32m it is working.
Sorry i have no more ideas what could be wrong.
