Displaying bitmap graphics on OLED
jhadd
Post by jhadd » Tue Jan 31, 2017 12:05 am
I'm trying to display simple monochrome bitmap graphics on a 128x64 OLED screen (SSD1306). It looks like there are simple ways to accomplish this with Arduino using Adafruit's GFX library, which has a drawbitmap method (see also here). Is there something similar for MicroPython?
Re: Displaying bitmap graphics on OLED
Post by pythoncoder » Tue Jan 31, 2017 8:43 am
As I suggested in response to your PM, I can see two approaches. One is to use the SSD1306 pixel method to output it in a bitwise fashion. The other is to use the framebuf's blit() method which looks as if it takes a buffer followed by destination x and y coordinates as arguments (see extmod/modframebuf.c).
This stuff is new so documentation is sparse; experimenting and testing are king...
Post by deshipu » Tue Jan 31, 2017 9:47 am
Here's an example program that displays the (old) MicroPython logo on the WeMos D1 Mini OLED shield. For a different display you need to modify the parameters passed to the driver. Also, note that you need to copy the ssd1306.py driver file to your ESP8266 for this to work.
import ssd1306
import framebuf
from machine import I2C, Pin
i2c = I2C(-1, Pin(5), Pin(4))
display = ssd1306.SSD1306_I2C(64, 48, i2c)
buffer = bytearray(b'\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xe0\x10\x8a\n0\x10$\xc8\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00x\xfe\xff?\xfe\xfd|\xfb\xf8\xfc\xff|\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x80\xc0@\xe0\xe0\xe0\xc0\xc1c\x9f\xff\x0f\xce\xff\xff\xcf\xe3\xf0pp\xa0\xe0\xe0\xc0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\xf0\xff\xfb\xe7\xdf\x8e\x9e\xfd\x95"$%\x00\xfe\xff\xff\xed\xdd\xce\xce\xff\xe7\xe7\xf7\xfb\xf9\xfep\xe0\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00@6\x9bg7\xcfo\x9d\xdb?\xbbws\xf7\xfa\xfa\xf9\xf4\xfd\xf7\xf3\xf1\xfdsy\xbd;\xd9\x9do\xcc6g\x9b6@\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00\x01\x00\x02\x01\x04\x03\t\x06\x13\x0c&\x19\r\x1b\x1b\r\x19&\x0c\x13\x06\t\x03\x04\x01\x02\x00\x01\x00\x00\x00\x00\x00\x00\x00\x00\x00\x00')
fb = framebuf.FrameBuffer(buffer, 48, 48, framebuf.MVLSB)
display.fill(0)
display.framebuf.blit(fb, 8, 0)
display.show()
I hope that helps.
Post by deshipu » Tue Jan 31, 2017 10:15 am
The buffer in the previous exampe is created by scanning the original image pixel-by-pixel and setting the bits of the bytes depending on whether they are supposed to be on or off. The alignment of the bytes is as follows (example of a 16x16 image, the digits signify the bits of each byte):
a7 b7 c7 d7 e7 f7 g7 h7 i7 j7 k7 l7 m7 n7 o7 p7
a6 b6 c6 d6 e6 f6 g6 h6 i6 j6 k6 l6 m6 n6 o6 p6
a5 b5 c5 d5 e5 f5 g5 h5 i5 j5 k5 l5 m5 n5 o5 p5
a4 b4 c4 d4 e4 f4 g4 h4 i4 j4 k4 l4 m4 n4 o4 p4
a3 b3 c3 d3 e3 f3 g3 h3 i3 j3 k3 l3 m3 n3 o3 p3
a2 b2 c2 d2 e2 f2 g2 h2 i2 j2 k2 l2 m2 n2 o2 p2
a1 b1 c1 d1 e1 f1 g1 h1 i1 j1 k1 l1 m1 n1 o1 p1
a0 b0 c0 d0 e0 f0 g0 h0 i0 j0 k0 l0 m0 n0 o0 p0
q7 r7 s7 t7 u7 v7 w7 x7 y7 z7 A7 B7 C7 D7 E7 F7
q6 r6 s6 t6 u6 v6 w6 x6 y6 z6 A6 B6 C6 D6 E6 F6
q5 r5 s5 t5 u5 v5 w5 x5 y5 z5 A5 B5 C5 D5 E5 F5
q4 r4 s4 t4 u4 v4 w4 x4 y4 z4 A4 B4 C4 D4 E4 F4
q3 r3 s3 t3 u3 v3 w3 x3 y3 z3 A3 B3 C3 D3 E3 F3
q2 r2 s2 t2 u2 v2 w2 x2 y2 z2 A2 B2 C2 D2 E2 F2
q1 r1 s1 t1 u1 v1 w1 x1 y1 z1 A1 B1 C1 D1 E1 F1
q0 r0 s0 t0 u0 v0 w0 x0 y0 z0 A0 B0 C0 D0 E0 F0
I used the following code to generate it:
import pygame
image = pygame.image.load("1bit-logo.png")
buffer = bytearray((image.get_height() // 8) * image.get_width())
i = 0
for y in range(image.get_height() // 8):
    for x in range(image.get_width()):
        byte = 0
        for bit in range(8):
            pixel = image.get_at((x, y * 8 + bit))
            if pixel[0] != 255:
                byte |= (1 << bit)
        buffer[i] = byte
        i += 1
print(repr(buffer))
kamikaze
Post by kamikaze » Tue Jan 31, 2017 12:08 pm
or you could use ImageMagick`s convert and store it in file to save RAM
Post by deshipu » Tue Jan 31, 2017 12:30 pm
Sure, I just thought that example code will be better for a precise explanation of the format. How you generate the data exactly is up to you, this is only an example.
Post by pythoncoder » Fri Feb 03, 2017 5:21 pm
deshipu wrote:... The alignment of the bytes is as follows (example of a 16x16 image, the digits signify the bits of each byte)...
I know I've carped about this before but I see we're still stuck with this weird SSD1306 pseudo-horizontal mapping. The SSD1306 does support a true vertical mapping. I have tested it in this mode and it works as expected. The framebuf is supposed (eventually) to support four mappings; alas this isn't one of them ;)
What would be your view on a PR to the official driver to use this mode? As far as I can see the mode has no intrinsic merit and we're using it because nobody has got round to fixing it. Or for fear of breaking code. Perhaps the mapping should be a runtime option to ssd1306.py, defaulting to weird.
Ideally the blit function would be capable of blitting between framebufs with heterogeneous mappings (but only the four variants discussed - vertical, horizontal, normal and bit-reversed). This isn't a priority for my current interest - font rendering - because I can generate any of the four agreed mappings.
Post by deshipu » Sat Feb 04, 2017 8:00 pm
pythoncoder wrote: What would be your view on a PR to the official driver to use this mode?
As you know, I have no say in this.
I would love to work on making the framebuf module really usable p -- adding support for more modes, for read-only buffers, for getting the size from Python, etc. -- alas, with no pull requests accepted, I'm not keen on doing work that would be wasted.
In the mean time I will just work on my own fork for my game engine, and if anybody wants to use any of that code, they are welcome to pull it into their implementation.
Post by pythoncoder » Sun Feb 05, 2017 6:19 am
deshipu wrote:As you know, I have no say in this...
I've now studied your updated modframebuf.c and have finally understood what you've been driving at. It does a great job of abstracting the physical layout of the buffer into three functions, so blits between heterogeneous framebufs should "just work". In principle my font_to_py.py code only needs to support one supported framebuf mode to support them all. Sorry it's taken me a while to cotton on :oops:
So there's no point in changing the SSD1306 mode.
I'll have a go at adding support to modframebuf.c for the four original modes (horizontal and vertical mappings with normal and reversed bit ordering) and test them with my font files. I'll submit a PR in due course - I'm in no hurry but I'd like to see fonts being rendered by blitting rather than bitwise as at present.
jgriessen
Post by jgriessen » Sat Jul 01, 2017 6:11 pm
I'm going to be wanting to use a LCD driver soon. Does any of what you two are working on translate to the driver adafruit uses? ILI9341/ILI9340 TFT displays? Is this only for ESP8266?
