UDP callbacks now working
dbalnaves
Post by dbalnaves » Fri Mar 03, 2017 11:53 pm
Hey Everyone,
I apologize in advance for any inaccurate use of terminology, failing to observe standards or just general ignorance. Please correct me as any guidance is really appreciated as it helps me learn.
So, thanks to a topic (http://forum.micropython.org/viewtopic.php?f=16&t=2854) some time ago where Roberthh sent me down the path of using TCP callbacks on esp8266 I was able to understand the code and found that support for UDP callbacks was fairly trivial.
$ git diff extmod/modlwip.c
diff --git a/extmod/modlwip.c b/extmod/modlwip.c
index 62699bd..b73d248 100644
--- a/extmod/modlwip.c
+++ b/extmod/modlwip.c
@@ -281,6 +281,7 @@ STATIC void _lwip_udp_incoming(void *arg, struct udp_pcb *upcb, struct pbuf *p,
         socket->incoming.pbuf = p;
         socket->peer_port = (mp_uint_t)port;
         memcpy(&socket->peer, addr, sizeof(socket->peer));
+       exec_user_callback(socket);
I get the impression that the use of setsockopt 20 is really just there to make webrepl work and is far from the decided approach. Does anybody know what the lasting approach will be going forward?
The point of this post was that I wanted to contribute this back to the community. UDP callbacks are so wonderful that everyone should have them; I wanted UDP callbacks to decrease latency for NTP (with milli support), but I imagine this would be attractive to people looking to implement mDNS. I'm happy to post some code that demonstrates this as working, but what should I do in order to contribute this back to the community?
dbalnaves
Re: UDP callbacks now working
Post by dbalnaves » Sat Mar 04, 2017 12:45 am
I did say I had some code to test this, this NTP code doesn't support subsecond but it demonstrates the callbacks:
    import usocket as socket
except:
    import socket
    import ustruct as struct
except:
    import struct
    import utime as time
except:
# (date(2000, 1, 1) - date(1900, 1, 1)).days * 24*60*60
NTP_DELTA = 3155673600
query_packet = bytearray(48)
response_packet = bytes(48)
dst_addr = socket.getaddrinfo('192.168.1.1', 123)[0][-1]
src_addr = socket.getaddrinfo('0.0.0.0', 123)[0][-1]
def ntp_cb(socket):
    msg = socket.recv(48)
    val = struct.unpack("!I", msg[40:44])[0]
    tm = time.localtime(val - NTP_DELTA)
    tupple = tm[0:3] + (0,) + tm[3:6] + (0,)
    machine.RTC().datetime(tupple)
    print(time.localtime())
print("running main")
while not webrepl.network.WLAN().isconnected():
    time.sleep(1)
print("Wifi connected: ",webrepl.network.WLAN().ifconfig())
NTP_QUERY = bytearray(48)
NTP_QUERY[0] = 0x1b
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.setsockopt(socket.SOL_SOCKET, 20, ntp_cb)
s.bind(src_addr)
    res = s.sendto(NTP_QUERY, dst_addr)
    time.sleep(1)
Which should produce output like this:
running main
connected with Utopia, channel 1
dhcp client start...
ip:192.168.1.17,mask:255.255.255.0,gw:192.168.1.1
Wifi connected:  ('192.168.1.17', '255.255.255.0', '192.168.1.1', '192.168.1.1')
(2017, 3, 4, 0, 43, 43, 5, 63)
(2017, 3, 4, 0, 43, 44, 5, 63)
(2017, 3, 4, 0, 43, 45, 5, 63)
(2017, 3, 4, 0, 43, 46, 5, 63)
(2017, 3, 4, 0, 43, 47, 5, 63)
(2017, 3, 4, 0, 43, 48, 5, 63)
(2017, 3, 4, 0, 43, 49, 5, 63)
(2017, 3, 4, 0, 43, 50, 5, 63)
larsks
Post by larsks » Wed Nov 08, 2017 12:39 pm
This looks like a really useful feature. It doesn't look like there was ever a reply here in the forum. Did you end up contributing this to the project?
