ESP-12 RTC Accuracy
devnull
ESP-12 RTC Accuracy
Postby devnull » Mon Mar 13, 2017 11:42 pm
I am using the in-built RTC on the 8266 to deepsleep for an hour, but it seems to be highly inaccurate, although it's repeatability seems to be OK.
    secs = 3600
    rtc = mc.RTC()
    rtc.irq(trigger=rtc.ALARM0, wake=mc.DEEPSLEEP)
    rtc.alarm(rtc.ALARM0, (secs*1000))
In sleeping for 1 hour, it wakes up on average 108 seconds early, this seems to be a huge error and of course in 1 day this would be roughly 43 minutes a day assuming that the error is cumulative.
Can the clock be so inaccurate ??
Other than adding a multiplication factor into the sleep time code, is there away to calibrate / adjust the rtc ?
filipmar.mf
Re: ESP-12 RTC Accuracy
Postby filipmar.mf » Tue Mar 14, 2017 8:54 am
I have the same observation. My "hour" has 57.5 min with amazing second precise repeatabilty with small minute variation time to time. Very strange behavior :?
Postby pythoncoder » Tue Mar 14, 2017 10:27 am
devnull
Postby devnull » Tue Mar 14, 2017 1:56 pm
Peter - thanks, but after reading through that it appears that the issue was fixed ??
https://github.com/micropython/micropython/pull/2726
Postby pythoncoder » Wed Mar 15, 2017 9:10 am
You haven't followed the chain to its end ;) See https://github.com/micropython/micropython/pull/2728. It has not yet been reviewed and accepted.
devnull
Postby devnull » Fri Mar 17, 2017 12:16 pm
Does not look like this is going to happen, 2728 has been closed / terminated, what a shame.
Postby pythoncoder » Fri Mar 17, 2017 3:55 pm
You can always fetch the PR and build it yourself. But it would be good to see it reviewed and merged.
Return to “ESP8266 boards”
Who is online
