ESP-12E module power consumption
JPM
Postby JPM » Sat Mar 18, 2017 9:49 am
Does anyone know the ESP-12E module power consumption when reset is activated ?.
Thanks in advance.
Re: ESP-12E module power consumption
Postby deshipu » Sat Mar 18, 2017 11:27 am
Do you have a multimeter?
JPM
Postby JPM » Sat Mar 18, 2017 12:44 pm
Yes I do but I am working with a ESP-12E development board and
I can't desolder the module VCC pin in order to meter current.
Postby deshipu » Sat Mar 18, 2017 5:59 pm
I'm asking, because the current consumption depends on many things: whether AP and station WiFi interfaces are active, what is being run from boot.py and main.py, potentially even details like the size of your flash chip or what pullups/pulldowns are installed on your board might affect it. So the best approach, I think, would be to measure your particular use case.
JPM
Postby JPM » Tue Mar 21, 2017 11:24 am
Thanks, I will try to meter the current.
Return to “ESP8266 boards”
Who is online
