[SOLVED] exec() function doesnt return result?
Posted: Mon Mar 27, 2017 6:35 pm
by VladVons
the following code works on Python for PC and prints Result
('Exec', 'Result = (2+3)*2', 'Result', 10)
But doesnt work on MicroPython ESP8266
NameError: name 'Result' is not defined
exec() listed in builtin MicroPython function, with no description or usage
http://docs.micropython.org/en/latest/w ... ltins.html
Any ideas?
def ExecScript(aValue = "Result = (2+3)*2"):
exec(aValue)
print("Exec", aValue, "Result", Result)
return Result
Re: exec() function doesnt work?
Posted: Mon Mar 27, 2017 7:47 pm
by stijn
IIRC with uPy's exec you have to pass the other 2 arguments as well, e.g.
loc = {}
exec('a=1', globals(), loc)
print(loc.a)
Posted: Mon Mar 27, 2017 8:53 pm
by VladVons
Doesnt work. Error:
AttributeError: 'dict' object has no attribute 'a'
Posted: Mon Mar 27, 2017 8:58 pm
by dhylands
Using loc['a'] will give better results.
Posted: Mon Mar 27, 2017 9:36 pm
by VladVons
thanks. works!
def Exec(aValue = "Result = (2+3)*2"):
Vars = {}
exec(aValue, globals(), Vars)
Result = Vars.get('Result')
except Exception as E:
Result = E
return Result
Re: [SOLVED] exec() function doesnt return result?
Posted: Tue Mar 28, 2017 7:29 am
by stijn
thanks!
Note that there's also built-in eval which for the case shown is simpler and less error-prone (by not forcing the statement passed in to have a Result variable bu instead just taking an expression):
def Exec(expression='(2+3)*2'):
return eval(expression)
except Exception as e:
return e
Note that returning expressions as a way of error-handling is rather non-pythonic and puts an extra burden on the caller of the function as now the return value has to be checked (can be None, a value, or an Exception) and makes it hard to distinguish between actual errors and e.g. Exec('Exception()')
Posted: Tue Mar 28, 2017 7:40 am
stijn wrote:...returning expressions as a way of error-handling is rather non-pythonic...
Indeed. I'd suggest having the caller do the exception handling.
Posted: Tue Mar 28, 2017 10:00 pm
by VladVons
eval calculates epressions only.
it cant call and execute methods or functions
eval("print('Hello World')")
SyntaxError: invalid syntax
Posted: Wed Mar 29, 2017 7:31 am
by stijn
That is not the correct definition of the difference between eval and exec. See e.g.
http://stackoverflow.com/questions/2220 ... -in-python
Eval
can call and exectude methods and functions:
>>> def foo():
return True
>>> eval('foo()')
True
At first I thought your example might not work because of escaping quotes but I realized that makes no sense.
And indeed it does actually work for me:
MicroPython v1.8.7-475-g406ff2f on 2017-03-23; win32 version
Use Ctrl-D to exit, Ctrl-E for paste mode
Hello World
I assume you are testing this on CPython 2 or so, that's not a good idea as differences with Python 3 and hence uPy are sometimes major.
