sometimes I get this output in the repl
LmacRxBlk:1
once it starts it repeats about every second, it even continues if you stop the program with a control c. seems the only way to stop it is with the reset buttion.
how do I find my bug that causing this?
Hal
strange behavior on esp board
Re: strange behavior on esp board
It's likely that you're not cleaning up and closing open sockets when they are no longer needed, or that the ESP8266 is being inundated with wifi packets and they are overflowing its internal buffers. Please see viewtopic.php?t=3260 for the same problem reported by another user.
I saw it too today after running:
Was having trouble with it, then realised, I upip installed the wrong version of urequests.
Uninstall:
(reset)
Install micropython version:
>>> import upip
>>> upip.install('urequests')
>>> res = urequests.get("http://example.com").json()
Uninstall:
>>> import os
>>> os.listdir()
['boot.py', 'lib']
>>> os.listdir('lib')
['urequests']
>>> os.listdir('lib/urequests')
['urequests.py']
>>> os.remove('lib/urequests/urequests.py')
>>> os.rmdir('lib/urequests')
>>> import upip
>>> upip.install('micropython-urequests')
>>> os.listdir('lib')
['urequests.py']
