I have an ESP8266 from Seedstuido which I flashed with esptool and all seems fine but the AP is not showing up afterwards. The blue led on esp is flickering though, I'm assuming this is indicative of wifi being operational.
So besides for creating a RS232 connection via UART0 (still to build cable for it) how else would I verify / connect to the device?
Thanks,
Output from flashing stage as follows,
esptool.py --port COM3 --baud 115200 write_flash --flash_mode dio --flash_size 4MB 0x0 .\images\esp8266-20170526-v1.9.bin
esptool.py v2.0-beta3
Connecting....
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Flash params set to 0x0240
Compressed 598084 bytes to 390425...
Wrote 598084 bytes (390425 compressed) at 0x00000000 in 34.4 seconds (effective
139.2 kbit/s)...
Hash of data verified.
Leaving...
Hard resetting...
AP not showing
Re: AP not showing
Resolved the issue, had to perform full erase before and then were able to get Python prompt via USB to serial interface.
