This small tool deploys your micropython code on your ESP board and it can optionally compile it too.
- Deploys full code structure (files/folders) on your board
- Allows you to specify which files to skip from the deployment process
- During development, espedite will deploy only the changed files on your board saving precious time
- Has the ability to cross-compile your code (.mpy) before deploying it to improve efficiency during importing
- Is able to uninstall (format) any code existing on the board
- Allows you to connect to the board immediately after code deployment
- Has full logging capabilities with color formatting
