[Newbie] send data to raspberry
enricosx
Post by enricosx » Fri Jun 16, 2017 2:32 pm
hello, i buy my first Nodemcu, flash micropython and now i want send text data (sensors or other) over wifi to my raspberrypi raspbian.
what is the best easy super simple way do to that? :D
Re: [Newbie] send data to raspberry
Post by deshipu » Fri Jun 16, 2017 4:30 pm
Maybe start with the examples in the "examples" directory?
ioukos
Post by ioukos » Sat Jun 17, 2017 5:44 am
It depends on what your application is, but to should have a look to bsd sockets or mqtt. Personnaly I use mqtt.
Post by pythoncoder » Mon Jun 19, 2017 6:51 am
+1 for MQTT. Run mosquitto on the Pi. Learn its use by running mosquitto_pub and mosquitto_sub between the Pi and a networked PC or between two PC's. Then install and use the umqtt libraries on your board. mosquitto is super-easy to use. I wrote some notes on MQTT here which may be of some use viewtopic.php?f=16&t=2239.
