A way to catch any exception?
eradicatore
Post by eradicatore » Fri Jun 23, 2017 5:56 am
I notice that when my python has an error, I get the REPL prompt on serial. Is there a way to do something in code when this exception happens, like blink an LED for example? Where is this REPL prompt coming from? Is it embedded in the micropython binary to go to that for unhandled exceptions?
Justin
Re: A way to catch any exception?
Post by pythoncoder » Fri Jun 23, 2017 8:24 am
This is a query about the Python language rather than anything specific to MicroPython. There are plenty of books and online tutorials which can help you and I suggest getting familiar with the language on a PC. In essence if your program stops for any reason (e.g. running to completion or throwing an exception), you get back to the REPL. To catch exceptions you use code like this:
    # something which might raise an OSError
except OSError:
    # Flash an LED
It is possible to catch and ignore any exception as below, but it is bad practice because syntax errors will be ignored so you'll never find your bugs.
    # lots of code
except:
    pass  # very bad idea
eradicatore
Post by eradicatore » Fri Jun 23, 2017 11:21 am
Ok, thanks! Yea, I was mainly asking about your comment "if it stops for any reason". I should have mentioned I'm already familiar with the try/except format, but was looking for a "global" version to do something if my board dies this way and I didn't have the try/except around the culprit
Damien
Site Admin
Post by Damien » Tue Jun 27, 2017 6:27 am
When a script finishes (either it runs to the end or has an uncaught exception) then the MicroPython runtime will go to the REPL.
If you want to catch any exception and handle that (eg reset the device) then do as suggested above, run your outer-most code in a try/except block, and do the error handling in the except.
radders
Post by radders » Wed Feb 06, 2019 2:15 pm
I've got some code:
    except OSError as exc:
        if exc.args[0] == uerrno.EWOULDBLOCK:
            print ('EWOULDBLOCK')
            time.sleep(1)           # short delay, no tight loops
which came from a sample on a forum, but I get errors at the uerrno line.
What is the correct implementation for this port of MicroPython, please?
Detecting when a nonblocking socket would block
Post by pythoncoder » Wed Feb 06, 2019 5:38 pm
I think the EWOULDBLOCK error dates back to an older version of Python. The correct line (for Python 3.4 and hence for MicroPython) is:
if err == errno.EAGAIN:
radders
Post by radders » Mon Mar 11, 2019 1:53 pm
Peter,
I'm getting:
NameError: name 'errno' isn't defined
Dave
kevinkk525
Post by kevinkk525 » Mon Mar 11, 2019 4:09 pm
You need to import errno.
Kevin Köck
radders
Post by radders » Wed Mar 20, 2019 2:02 pm
TY. Simple when you know how :lol:
