I searched the board an the source for uP ESP2866 edition, but didn't find anything related to this.
According to the documentation of my ESP2866 12E, GPIO15 should be SPI 1 chip select.
However it does not toggle when I transfer data (as verified by my scope). MOSI and CLK work just fine.
The driver source seems to be here:
https://github.com/micropython/micropyt ... spi.c#L100
The comment is a bit cryptic for me to understand. So I guess the bottom line is: can the hardware CS be activated, or do I have to emulate it myself?
HSPI chip select
Re: HSPI chip select
maybe you find more answers looking for the Esp8266 instead of the ESP2866
But yes, as far as I can tell (never used SPI with micropython) CS is not implemented by the generic SPI driver. However, as it is a simple io action, one can simply create a Pin instance to do the job and wrap this into a function together with the original SPI read and write.
I ALWAYS flip the numbers
I'm not sure how the SPI driver works. If I'm synchronous your approach is fine. If it's IRQ driven, the real CS would allow to spawn a transfer while e.g. serving a timer callback.
Is that known?
Is that known?
