Firmware for esp8266 work fine on esp8285 board but I can't use GPIO 7 and 8. I see error "invalid pin number".
My device is Sonoff 4ch.
Esp8285 GPIO 7 and 8
Re: Esp8285 GPIO 7 and 8
7 and 8 are not valid pin numbers for the ESP82xx. See here: http://docs.micropython.org/en/latest/e ... s-and-gpio
You might be confusing the MCU pin number with the nomenclature used for the pins of NodeMCU compatible boards. Here's the mapping: https://github.com/nodemcu/nodemcu-devkit-v1.0
