The driver [winbond.py]:
The following class acts as a simple driver for Winbond Serial Flash Memory chips (for the ESP8266). Some people searching around this forum might want to use it as a template (no caching, so it is very slow in writing, ~1-5 kBps). It was tested with a W25Q32 and W25Q256 on a ESP-12, but the others (like W25Q128 or W25Q80) should work as well.
# winbond.py
from micropython import const
class W25QFlash:
SECTOR_SIZE = const(4096)
BLOCK_SIZE = const(512)
PAGE_SIZE = const(256)
def __init__(self, spi, cs, baud=40000000):
self.cs = cs
self.spi = spi
self.cs.init(self.cs.OUT, value=1)
self.spi.init(baudrate=baud, phase=1, polarity=1) # highest possible baudrate is 40 MHz for ESP-12
self._cache = bytearray(self.SECTOR_SIZE) # buffer for writing single blocks
self._CAPACITY = self.identify() # calc number of bytes (and makes sure the chip is detected and supported)
self._ADR_LEN = 3 if (len(bin(self._CAPACITY-1))-2) <= 24 else 4 # address length (default: 3 bytes, 32MB+: 4)
# setup address mode:
if self._ADR_LEN == 4:
if not self._read_status_reg(16): # not in 4-byte mode
print("entering 4-byte address mode")
self._await()
self.cs(0)
self.spi.write(b'\xB7') # 'Enter 4-Byte Address Mode'
self.cs(1)
def identify(self):
# Determines manufacturer and device id and raises an error if the device is not detected or
# not supported. Returns the number of blocks (calculated based on the detected chip).
self._await()
self.cs(0)
self.spi.write(b'\x9F') # 'Read JEDEC ID'
mf, mem_type, cap = self.spi.read(3, 0x00) # manufacturer id, memory type id, capacity id
self.cs(1)
if not (mf and mem_type and cap): # something is 0x00
raise OSError("device not responding, check wiring. (%s, %s, %s)" % (hex(mf), hex(mem_type), hex(cap)))
if mf != 0xEF or mem_type not in [0x40, 0x60]: # Winbond manufacturer, Q25 series memory (tested 0x40 only)
raise OSError("manufacturer (%s) or memory type (%s) not supported" % (hex(mf), hex(mem_type)))
print("manufacturer:", hex(mf))
print("device:", hex(mem_type << 8 | cap))
print("capacity: %d bytes" % int(2**cap))
return 2**cap # calculate number of bytes
def format(self):
# Performs a chip erase, which resets all memory to 0xFF (might take a few seconds/minutes).
# Important: Run os.VfsFat.mkfs(flash) to make the flash an accessible file system.
# As always, you will then need to run os.mount(flash, '/MyFlashDir') then.
self._wren()
self._await()
self.cs(0)
self.spi.write(b'\xC7') # 'Chip Erase'
self.cs(1)
self._await() # wait for the chip to finish formatting
def _read_status_reg(self, nr): # Returns the value (0 or 1) in status register <nr> (S0, S1, S2, ...)
reg, bit = divmod(nr, 8)
self.cs(0)
self.spi.write((b'\x05', b'\x35', b'\x15')[reg]) # 'Read Status Register-...' (1, 2, 3)
stat = 2**bit & self.spi.read(1, 0xFF)[0]
self.cs(1)
return stat
def _await(self): # Waits for device not to be busy and returns if so
self.cs(0)
self.spi.write(b'\x05') # 'Read Status Register-1'
while 0x1 & self.spi.read(1, 0xFF)[0]: # last bit (1) is BUSY bit in stat. reg. byte (0 = not busy, 1 = busy)
pass
self.cs(1)
def _sector_erase(self, addr): # Resets all memory within the specified sector (4KB) to 0xFF
self._wren()
self._await()
self.cs(0)
self.spi.write(b'\x20') # 'Sector Erase'
self.spi.write(addr.to_bytes(self._ADR_LEN, 'big'))
self.cs(1)
def _read(self, buf, addr):
# Reads len(<buf>) bytes from the chip - starting at <addr> - into <buf>. To keep things
# easy, len(<buf>) has to be a multiple of self.SECTOR_SIZE (or even better: less than that).
print("read %d bytes starting at %s" % (len(buf), hex(addr)))
assert addr+len(buf) <= self._CAPACITY, \
"memory not addressable at %s with range %d (max.: %s)" % \
(hex(addr), len(buf), hex(self._CAPACITY-1))
self._await()
self.cs(0)
self.spi.write(b'\x0C' if self._ADR_LEN == 4 else b'\x0B') # 'Fast Read' (0x03 = default), 0x0C for 4-byte mode
self.spi.write(b'\xFF') # dummy byte
self.spi.readinto(buf, 0xFF)
self.cs(1)
def _wren(self): # Sets the Write Enable Latch (WEL) bit in the status register
self._await()
self.cs(0)
self.spi.write(b'\x06') # 'Write Enable'
self.cs(1)
def _write(self, buf, addr):
# Writes the data from <buf> to the device starting at <addr>, which has to be erased (0xFF)
# before. Last byte of <addr> has to be zero, which means <addr> has to be a multiple of
# self.PAGE_SIZE (= start of page), because wrapping to the next page (if page size exceeded)
# is implemented for full pages only. Length of <buf> has to be a multiple of self.PAGE_SIZE,
# because only full pages are supported at the moment (<addr> will be auto-incremented).
print("write buf[%d] to %s (%d)" % (len(buf), hex(addr), addr))
assert len(buf) % self.PAGE_SIZE == 0, "invalid buffer length: %d" % len(buf)
assert not addr & 0xf, "address (%d) not at page start" % addr
for i in range(0, len(buf), self.PAGE_SIZE):
self._wren()
self._await()
self.cs(0)
self.spi.write(b'\x02') # 'Page Program'
self.spi.write(buf[i:i+self.PAGE_SIZE])
addr += self.PAGE_SIZE
self.cs(1)
def _writeblock(self, blocknum, buf):
# To write a block, the sector (eg 4kB = 8 blocks) has to be erased first. Therefore, a sector will be read
# and saved in cache first, then the given block will be replaced and the whole sector written back when
assert len(buf) == self.BLOCK_SIZE, "invalid block length: %d" % len(buf)
print("writeblock(%d, buf[%d])" % (blocknum, len(buf)))
sector_nr = blocknum // 8
sector_addr = sector_nr * self.SECTOR_SIZE
index = (blocknum << 9) & 0xfff # index of first byte of page in sector (multiple of self.PAGE_SIZE)
self._read(self._cache, sector_addr)
self._cache[index:index+self.BLOCK_SIZE] = buf # apply changes
self._sector_erase(sector_addr)
self._write(self._cache, sector_addr) # addr is multiple of self.SECTOR_SIZE, so last byte is zero
def readblocks(self, blocknum, buf):
# Read data from the chip starting at block number <blocknum> to <buf> (len = multiple of self.BLOCK_SIZE)
assert len(buf) % self.BLOCK_SIZE == 0, 'invalid buffer length: %d' % len(buf)
buf_len = len(buf)
if buf_len == self.BLOCK_SIZE:
self._read(buf, blocknum << 9)
offset = 0
buf_mv = memoryview(buf)
while offset < buf_len:
self._read(buf_mv[offset:offset+self.BLOCK_SIZE], blocknum << 9)
offset += self.BLOCK_SIZE
blocknum += 1
def writeblocks(self, blocknum, buf):
# Writes the content from <buf> (len must be multiple of self.BLOCK_SIZE) to block number <blocknum>
buf_len = len(buf)
self._writeblock(blocknum, buf)
offset = 0
self._writeblock(blocknum, buf_mv[offset:offset+self.BLOCK_SIZE])
blocknum += 1
def count(self): # Returns the number of blocks (self.BLOCK_SIZE bytes) available on the device
return int(self._CAPACITY / self.BLOCK_SIZE)
Or you could use the following version of winbond.py, which uses the cached sector, so that writing will be a bit faster for big files (no faster reading). But you always have to call the sync() method to apply the changes before shutting the ESP or the memory chip down.
# winbond.py
class W25QFlash:
self.cs = cs
self.spi = spi
self._cache_saddr = None # address of the sector that is currently cached
self._cache_isdirty = False # set to True if the data has not been written back to the chip
bin(self._CAPACITY - 1)) - 2) <= 24 else 4 # address length (default: 3 bytes, 32MB+: 4)
self._await()
self.cs(0)
self.cs(1)
def identify(self):
self._await()
self.cs(0)
self.cs(1)
#print("manufacturer:", hex(mf))
#print("device:", hex(mem_type << 8 | cap))
#print("capacity: %d bytes" % int(2 ** cap))
return 2 ** cap # calculate number of bytes
def format(self):
self._wren()
self._await()
self.cs(0)
self.cs(1)
self.cs(0)
stat = 2 ** bit & self.spi.read(1, 0xFF)[0]
self.cs(1)
return stat
self.cs(0)
pass
self.cs(1)
self._wren()
self._await()
self.cs(0)
self.cs(1)
#print("read %d bytes starting at %s" % (len(buf), hex(addr)))
#assert addr + len(buf) <= self._CAPACITY, \
# "memory not addressable at %s with range %d (max.: %s)" % \
# (hex(addr), len(buf), hex(self._CAPACITY - 1))
if self._cache_saddr is not None:
buf_len = len(buf)
if self._cache_saddr <= addr and addr+buf_len <= self._cache_saddr+self.SECTOR_SIZE:
# section is completely cached, so simply read from cache
buf[:] = self._cache[addr-self._cache_saddr:addr-self._cache_saddr+buf_len]
return # do not read from memory
elif addr < self._cache_saddr < addr+buf_len or addr < self._cache_saddr+self.SECTOR_SIZE < addr+buf_len:
# part of the section is in cache, so write back if required before reading all from memory
self.sync()
self._await()
self.cs(0)
self.cs(1)
self._await()
self.cs(0)
self.cs(1)
#print("write buf[%d] to %s (%d)" % (len(buf), hex(addr), addr))
#assert len(buf) % self.PAGE_SIZE == 0, "invalid buffer length: %d" % len(buf)
#assert not addr & 0xf, "address (%d) not at page start" % addr
self._wren()
self._await()
self.cs(0)
self.spi.write(buf[i:i + self.PAGE_SIZE])
self.cs(1)
#assert len(buf) == self.BLOCK_SIZE, "invalid block length: %d" % len(buf)
#print("writeblock(%d, buf[%d])" % (blocknum, len(buf)))
if sector_addr != self._cache_saddr: # sector not cached -> put in cache
self.sync() # write back previously cached sector first (apply old changes)
self._cache_saddr = sector_addr
self._cache[index:index + self.BLOCK_SIZE] = buf # perform changes in cache
self._cache_isdirty = True # sync() has to be called to apply the changes!
#print("READ %d bytes starting at block %d" % (len(buf), blocknum))
#assert len(buf) % self.BLOCK_SIZE == 0, 'invalid buffer length: %d' % len(buf)
buf_len = len(buf)
offset = 0
self._read(buf_mv[offset:offset + self.BLOCK_SIZE], blocknum << 9)
blocknum += 1
#print("WRITE %d bytes starting at block %d" % (len(buf), blocknum))
buf_len = len(buf)
offset = 0
self._writeblock(blocknum, buf_mv[offset:offset + self.BLOCK_SIZE])
blocknum += 1
def sync(self): # Writes back the sector from cache to the chip (required to apply the changes!)
if self._cache_isdirty:
self._sector_erase(self._cache_saddr)
self._write(self._cache, self._cache_saddr) # addr is multiple of self.SECTOR_SIZE, so last byte is zero
Usage:
First of all, the wiring has to be ok, otherwise you won't even get the manufacturer information (__init__ method will fail). VCC and GND connected. DI/IO0 to MOSI/13, DO/IO1 to MISO/12, CLK to SCK/14 and CS to pin 15 (or any pin you like). Make sure to add pull-up resistors. Especially HOLD (and RESET) should be pulled up (or connected to VCC directly if not required)!
import machine, os, winbond
flash = winbond.W25QFlash(machine.SPI(1), machine.Pin(15))
flash.format() # !!! only required on the very first start (will remove everything); takes some seconds/minutes!
os.VfsFat.mkfs(flash) # !!! only required on first setup and after formatting
os.mount(flash, '/win') # after every reboot of the ESP
#os.chdir('win')
