ure - regular expressions api
cagiva
Post by cagiva » Sun Oct 29, 2017 1:29 am
Why doesn't ure have the ure.sub() or match.groupdict() functions? Is there a workaround for that in the MicroPython?
cagiva
Re: ure - regular expressions api
Post by cagiva » Mon Oct 30, 2017 7:41 am
I was able to make it work without sub() and groupdict(). However, I cannot figure out why this generates ValueError: Error in regex, but it run perfectly fine with standard Python re api.
import ure
ure.compile('^{}$'.format('/cam/(?P<epoch>.+)'))
SpotlightKid
Post by SpotlightKid » Mon Oct 30, 2017 7:17 pm
From the documentation:
Counted repetitions ({m,n}), more advanced assertions, named groups, etc. are not supported.
(My emphasis)
Post by pythoncoder » Tue Oct 31, 2017 5:23 am
@cagiva I suggest you read https://github.com/micropython/micropyt ... ifferences for some insight into the MicroPython micro libraries.
cagiva
Post by cagiva » Tue Oct 31, 2017 6:13 am
Hi Peter,
I'm well aware that MicroPython does not support the entire python standard library. However, it will be great if the core team can consider extending the basic grouping syntax to add named-groups. It's a very helpful feature for parsing dynamic URIs/URLs containing named gapturing groups. In particular for those running with the ESP8266 boards.
This would be a change to extmod/modure.c and it should not make its implementation that much heavier for the small platforms.
