Load json
Mark.Calaway
Load json
Post by Mark.Calaway » Sun Oct 29, 2017 4:29 pm
Hi guys,
I would like to load some parameters from a json file.
I wrote an example:
# mqtt.py :
import ujson
with open('document.json') as data_file:
data = ujson.loads(data_file)
yourWifiSSID = data["wifi"]["SSD"]
yourWifiPassword = data["wifi"]["password"]
print('SSD: {} & pass: {}',yourWifiSSID,yourWifiPassword)
And the json file:
# document.json :
"wifi": {
"SSD": "nome",
"password": "pass"
What i was wrong?
benalb
Re: Load json
Post by benalb » Mon Oct 30, 2017 11:05 am
Hi guys,
I wrote an example:
# mqtt.py :
import ujson
What i was wrong?
The docs says: ujson.loads(str), Parse the JSON str and return an object. Raises ValueError if the string is not correctly formed.
so, you must pass the content of data_file as a string: data = ujson.loads(str(data_file.readlines()))
Mark.Calaway
Re: Load json
Post by Mark.Calaway » Mon Oct 30, 2017 4:21 pm
[quote="benalb"]
[/quote]
Thx, i have another question: i need to close the file in the end?
data_file.closed
SpotlightKid
Re: Load json
Post by SpotlightKid » Mon Oct 30, 2017 7:13 pm
This should be:
with open(filename) as fp:
	data = ujson.loads(fp.read())
The readlines method of file objects returns the contents of the file as a list of lines (strings), which is not what we want here.
But contrary to the documentation, at least in the unix port of MicroPython, the ujson modul also supports the load function, which takes indeed a file object instead of the string, so that would be:
	data = ujson.load(fp)
Notice the missing trailing 's' in the function name.
benalb
Re: Load json
Post by benalb » Mon Oct 30, 2017 7:45 pm
This should be:
(... do not use readlines)
I stand corrected. After test the code, I see that ujson.load is the correct way. :oops:
Mark.Calaway
Re: Load json
Post by Mark.Calaway » Mon Oct 30, 2017 8:07 pm
[quote=SpotlightKid post_id=22857 time=1509390816 user_id=552]
This should be:
[code]
[/code]
The [i]readlines[/i] method of file objects returns the contents of the file as a list of lines (strings), which is not what we want here.
But contrary to the documentation, at least in the unix port of MicroPython, the [i]ujson[/i] modul also supports the [i]load[/i] function, which takes indeed a file object instead of the string, so that would be:
[code]
[/code]
[/quote]
Thx for your help.
They need to fix this mistake in the docs page.
SpotlightKid
Re: Load json
Post by SpotlightKid » Mon Oct 30, 2017 9:01 pm
No, this is taken care of by the with statement, which makes fp a context manager, which closes the file at the end of the with-block.
