https://docs.micropython.org/en/latest/ ... intro.html
pip install esptool
pip install esptool
python -V
pip -V
"pip" is a command line tool that you run from the Windows command prompt as opposed to via the Python text interface (i.e. the REPL). In other words, you'll need to run the "pip install esptool" command before starting "python". In fact, when using "pip" to install "esptool", it will create an "esptool.exe" file in the "Scripts" directory of your Python installation. You can hence run "esptool" from the Windows command prompt and it will take care of invoking Python for you in order to run.when I type it into Python
