Page 1 of 2
how can I implement time scheduling in micropython
Posted: Mon Dec 04, 2017 11:08 pm
by zedtech
How can i implement a similar to below time scheduling code in micropython??
from datetime import datetime
turnon_time = "16:41:00"
turnoff_time = "16:45:00"
current_time = datetime.strftime(datetime.now(),"%H:%M:%S") #output: 11:12:12
#print(current_time)
if current_time == turnon_time:
print("Turned the Lights on!")
elif current_time == turnoff_time:
print("Turned the lights off!")
I tried the following code below but with no success. current_time prints only once, its not been updated. Why is that when its in the while loop?
LED_YELLOW = machine.Pin(15,machine.Pin.OUT)
turnon_time = "18:45:00"
turnoff_time = "07:00:00"
rtc.datetime((2017, 12, 4, 0, 14, 17, 0, 0))
t = time.localtime()
current_time = '{:02d}:{:02d}:{:02d}'.format(t[3],t[4],t[5])
print(current_time)
if LED_YELLOW.value():
pass
LED_YELLOW.on()
print('Yellow Led On')
LED_YELLOW.off()
pass
Re: how can I implement time scheduling in micropython
Posted: Tue Dec 05, 2017 7:55 am
It's hard to figure out why your code doesn't run since the forum doesn't allow code posts until you've posted a few messages. So I can't see your indentation. But the following does work - tested on an ESP8266. Note I changed the on time so you only have to wait a minute to see the LED turn on.
rtc = machine.RTC()
turnon_time = "14:18:00"
print(current_time)
if not LED_YELLOW.value():
LED_YELLOW.on()
LED_YELLOW.off()
print('Yellow Led Off')
time.sleep(0.3)
Posted: Tue Dec 05, 2017 8:40 am
by SpotlightKid
pythoncoder wrote: ↑Tue Dec 05, 2017 7:55 am
A workaround for this is use the quote message function, then you'll see the markup of the original post with the indentation intact.
Posted: Tue Dec 05, 2017 8:58 am
So it does! Thank you.
Posted: Thu Dec 07, 2017 2:21 am
by zedtech
[quote=pythoncoder post_id=23678 time=1512460525 user_id=265]
[code]import machine
rtc = machine.RTC()
print(current_time)
LED_YELLOW.on()
LED_YELLOW.off()
time.sleep(0.3)
[/code]
[/quote]
Hello, Thanks a million for your help. My code if exactly as you wrote except It doesn't have the time.sleep(0.3) part at the end and if yours worked then i'm going to make the time.sleep(0.3) addition to my code and see if it will work. Anyways what is the need for time.sleep(0.3)?
Posted: Thu Dec 07, 2017 10:18 am
Simply to reduce the rate it prints out. My version will work without it.
As a general point in a more complex program I wouldn't compare text strings. This is because if you don't check it more than once per second there is a risk of missing the time. I would convert hours, minutes and seconds to an integer number of seconds past midnight. Then you can compare times with something along the lines of
if current_time >= turnon_time and not LED_YELLOW.value():
LED_YELLOW.on()
elif current_time >= turnoff_time and LED_YELLOW.value():
LED_YELLOW.off()
This will work even the code runs at a lower rate than 1Hz.
Posted: Thu Dec 07, 2017 8:12 pm
by zedtech
Once again thanks very much for your help. My actual entire code in the while loop on the ESP8266 had other parts besides of the time comparison. when i remove it, the time comparison worked. But i want to keep the other part too. How can this be done? Any suggestions will be highly appreciated.
Here is the overview of the project that i'm working on. In the while loop the script is suppose to check if the time comparison has happened and perform some action. After that its suppose to check if there's a network connection from an mobile app device and if true perform some actions as well and the cycle should repeat over and over. As the script is below current_time doesn't get update.
t = utime.locatime()
LED_YELLOW.on()
LED_YELLOW.off()
conn, addr = s.accept()
print("Got a connection from %s" % str(addr))
request = conn.recv(1024)
print("Content = %s" % str(request))
request = str(request)
if request.find('/?STATUS='):
STAT = str(request[15:22])
STATUS = STAT.strip()
if STATUS == 'REDOON':
LED_RED.on()
content = 'Kitchen Light On'
elif STATUS == 'REDOFF':
LED_RED.off()
content = 'Kitchen Light Off '
response = http % (len(content), content)
conn.send(response)
conn.close()
utime.sleep(0.3)
Moderator note: I added code tags to your post so that the indentation would be presented properly.
Posted: Thu Dec 07, 2017 10:30 pm
by kfricke
zedtech wrote: ↑Thu Dec 07, 2017 2:21 am
... Anyways what is the need for time.sleep(0.3)?
The ESP8266 RTOS (which MicroPythonactually runs embedde in) needs time slices to do the work to keep the WiFi functionalites up and running (especially in AP mode).
Posted: Fri Dec 08, 2017 1:50 am
by zedtech
Its a pause and the code still works without it. I just followed the suggestion of someone and by adding it to my code thought it would clear up the issue with my code, but the issue was something else.
Posted: Fri Dec 08, 2017 6:57 am
You're almost certainly hitting the problem I explained in my last post. The way your code works relies on the string comparison being performed at least once per second. The test
will only succeed if it runs at that precise time. Say the turnon_time is '12:00:00' and the time at the start of the loop is '11:59:59'. The test will (correctly) fail and the LED will remain off. The rest of the code runs with all the internet stuff taking (say) 5 seconds. On the next pass through the loop current_time == '12:00:04' and the test will again fail. The LED will never turn on.
The solution (as I said before) is to convert the times to integers instead of strings and perform a >= comparison. Thus:
current_time = t[3]*3600 + t[4]*60 +t[5] # Seconds since midnight
The trigger times would be handled similarly
TURN_YELLOW_ ON = (14, 05, 00) # Turn on at 14:05:00
TURN_YELLOW_OFF = (08, 05, 30) # Off at 08:05:30
def time_to_int(t):
return t[0]*3600 + t[1]*60 + t[2]
turnon_time = time_to_int(TURN_YELLOW_ ON)
turnoff_time = time_to_int(TURN_YELLOW_ OFF)
Then your comparison would be performed by
if current_time >= turnon_time and LED_YELLOW.value():
This will work even if the subsequent part of the loop takes minutes to run since the >= test will pass.
