[Kinda SOLVED] String Methods missing
yeyeto2788
Post by yeyeto2788 » Mon Dec 11, 2017 2:33 pm
Hello guys!
Does anyone of you has use strings methods on your code?
I'm trying to use the following:
str.center(width, fillchar)
str.ljust(width, fillchar)
str.rjust(width, fillchar)
str.title()
and none of those worked :( here you have the output from the REPL:
MicroPython v1.9.2-8-gbf8f45cf on 2017-08-23; ESP module with ESP8266
>>> a = "pepito"
>>> a.center(10,"*")
AttributeError: 'str' object has no attribute 'center'
>>> a.rjust(10,"*")
AttributeError: 'str' object has no attribute 'rjust'
>>> a.ljust(10,"*")
AttributeError: 'str' object has no attribute 'ljust'
>>> a.title()
AttributeError: 'str' object has no attribute 'title'
>>> b = a.title()
Note: I have looked at the documentation but no reference to those.
http://docs.micropython.org/en/latest/p ... ltins.html
Regards.
UPDATE
I got it to work with
.format
as follow:
a = "hola"
print('{:*^10}'.format(a))
Re: [Kinda SOLVED] String Methods missing
Post by Roberthh » Mon Dec 11, 2017 3:08 pm
.format
That's indeed the proposed method, to keep MicroPython micro. There were discussions already around that topic, if not in the forum, then in the github repository.
pfalcon
Post by pfalcon » Sat Dec 16, 2017 8:48 am
But the main source of information is the documentation: http://docs.micropython.org/en/latest/p ... mplemented
Can be found easily by searching docs by "ljust": http://docs.micropython.org/en/latest/p ... ea=default
