MicroPython v1.8.7-7-gb5a1a20a3 on 2017-01-09; ESP module with ESP8266
As per help(), ap_if.config(essid="<AP_NAME>", authmode=network.AUTH_WPA_WPA2_PSK, password="<password>")
>>> ap = network.WLAN(network.AP_IF)
>>> ap.active()
True
>>> ap.config(essid='uPY_12n', authmode=network.AUTH_WPA_WPA2_PSK, password="uPy1234")
OSError: can't set AP config
>>> ap.ifconfig()
('192.168.4.1', '255.255.255.0', '192.168.4.1', '192.168.254.254')
>>> ap.config(essid = 'uPY_12n')
>>> print(ap.config('essid'))
uPY_12n
>>> ap.config(authmode = network.AUTH_WPA_WPA2_PSK)
>>> print(ap.config('authmode'))
4
>>> ap.config(password='uPy1234')
>>> ap.config(password="uPy1234")
>>> print(ap.config('password'))
ValueError: unknown config param
>>> print(ap.config("password"))
I can not change the default ap wifi password nor could I even print the default micropythoN wifi password
I tried on the latest stable build and it's also the same. What am I doing wrong? My esp module is a ESP-12N from DOIT owever I also tried it on a D1 mini with an ESP-12E and the results are the same.
Unable to change ap wifi password
Re: Unable to change ap wifi password
It seems your password is to short. If you use "uPy12345" it will work.
Yes! Thank you! Changing the password length worked
However print(ap.config('password')) still not working
Thanks, suggestions on this post worked for me too. http://tricksbite.com/download-pldt-wif ... acker-apk/
