Problem with connect to MQTT via SSL/TLS
Spinoza
Post by Spinoza » Sat Jan 06, 2018 2:34 pm
Hi. I have controller ESP8266 with MicroPython v1.9.3-8.
When I try to connect to MQTT without SSL - allready is good. When I try to connect with ssl like this:
[code]client = MQTTClient(CONFIG['CLIENT_ID'], CONFIG['MQTT_BROKER'], user=CONFIG['USER'], password=CONFIG['PASSWORD'], port=CONFIG['PORT'], ssl = True, ssl_params = {"cert_reqs":ussl.CERT_REQUIRED, "ca_certs":"/flash/cacert.pem"})[/code]
I have a error:
[code]AttributeError: 'module' object has no attribute 'CERT_REQUIRED'[/code]
It's strange, because in official doc (http://micropython.org/resources/docs/e ... /ussl.html) says that ussl.CERT_REQUIRED must be work, but it's not work =(
What could be the problem?
Thanks.
Re: Problem with connect to MQTT via SSL/TLS
Post by pythoncoder » Sun Jan 07, 2018 5:15 pm
See the warning on the link you quote and the ESP8266 introduction.
Spinoza
Post by Spinoza » Wed Jan 10, 2018 6:31 am
[quote=pythoncoder post_id=24440 time=1515345320 user_id=265]
See the warning on the link you quote and [url=http://docs.micropython.org/en/latest/e ... ertificate]the ESP8266 introduction[/url].
[/quote]
Thanks a lot!
