Uart communication
misisnik
Uart communication
Post by misisnik » Wed Jan 17, 2018 7:40 am
Hello
I have a problem with UART0 communication with my PC from ESP8266.
My main.py code looks like (it should send magnetometer data throw UART)
from lsm303e import LSM303
i2c = I2C(scl=Pin(5), sda=Pin(4), freq=400000)
lsm303 = LSM303(i2c)
p2 = Pin(2, Pin.OUT)
#and send the data
uart = UART(0, 9600)
uart.init(9600, bits=8, parity=None, stop=1)
while 1:
time.sleep(0.001)
uart.write(str(lsm303.mag_read())+'\n')
And when I want to read this data in my PC (I am using cp2100), none of the data had come. UART REPL mode in boot.py is running without problem with this usb to uart converter.
My python code in my PC for reading uart data is:
import serial
ser = serial.Serial('/dev/ttyUSB0', 9600)
while 1:
print(str(ser.readline()))
time.sleep(0.5)
Where is problem? I have not see any :)
THX Mike
Re: Uart communication
Post by Roberthh » Wed Jan 17, 2018 11:18 am
Since UART0 ist used for REPL, you can on the ESP8266 simple print() what you want to send. No need to use the UART API.
