Network scan callback
misisnik
Post by misisnik » Thu Feb 01, 2018 8:33 am
Hello
is it possible to set callback when network scan (get RSSI and MAC address of APs) is in process?
This scan takes at least 2 seconds and in this time I want to do another things with i2c and get the scan result when is done.
Thanks Mike
misisnik
Re: Network scan callback
Post by misisnik » Fri Mar 09, 2018 2:29 pm
Is it possible to do wlan scan faster or to run it with uasincio and pulling data from i2c while wlan scan has running????
Post by pythoncoder » Sun Mar 11, 2018 11:28 am
The network.scan method is a blocking function and does not return to the caller until it has results. So uasyncio won't help you: it's a cooperative scheduler which requires non-blocking functions to work in a timely fashion. Your only chance is to use _thread which is a pre-emptive scheduler. Alas I have no experience of this on the ESP8266: the hardware is resource constrained and threading is more demanding than uasyncio. Perhaps others can advise.
