Page 2 of 2
Re: pin change interrupt + debouncing
Posted: Mon Apr 09, 2018 5:39 pm
Thanks, but I'm afraid that isn't my code
That demo shows the speed of refresh but doesn't use the touch facility.
My GUI is a simplified touch interface which allows you to create objects like pushbuttons, sliders, dropdown lists and suchlike. These respond visually to touch and run callbacks like a very stripped down version of a tablet/phone GUI. Alas I haven't made a video but there are some stills on the link above.
@grafalex
The comments about CPU cycles are valid. However if you opt for the
uasyncio approach (which I recommend) the module is based around polling. You don't have any option to control its usage of CPU cycles. If, in the context of a
uasyncio application, you choose to use interrupts to interface to a specific device the only thing you will gain is performance.
In terms of detecting 1s pulses you will have no problem whatsoever unless your coroutines are badly designed. For example if you issue
pyb.delay(3000) in a coroutine you'll miss pulses because you're stopping the scheduler for 3s. Issuing
await asyncio.sleep(3) will fix the problem. In a sensibly designed application I'd expect response times to a switch state change to be under 50ms. The underlying speed of
uasyncio context switching on a Pyboard is well under 1ms. In practice latency depends on the degree to which individual coroutines hog the CPU.
I have based some fairly complex (for the Pyboard) applications around my GUI code. I've yet to encounter a situation where the response to pressing a screen object wasn't visually instantaneous.
Posted: Mon Apr 09, 2018 8:19 pm
by OutoftheBOTS_
@dhylands
the way I typically do it is that the interrupt handler disables itself and starts a debounce timer.
This is what I have done with Ardunio but I can't find out how to pause an interrupt in Micro-Python.
Posted: Mon Apr 09, 2018 10:43 pm
by dhylands
If you're using ExtInt to detect the pin change, then there is a disable/enable methods available:
http://docs.micropython.org/en/latest/p ... nt.disable
Posted: Tue Apr 10, 2018 3:44 am
by OutoftheBOTS_
Is this only available on the pyboard??
I have used the pin.irq in these docs
http://docs.micropython.org/en/v1.9.3/e ... /pins.html
Posted: Tue Oct 02, 2018 10:04 pm
by jedie
I have made this:
https://gist.github.com/jedie/8564e62b0 ... c5a1312ed7
But i'm just a microPython rookie. Any suggestions?
Posted: Wed Oct 03, 2018 7:20 am
The approach looks right but you really need to ensure that each pin uses a separate timer in case two pins change in quick succession. This would get expensive on timers if you had a lot of switches.
Another approach is to use
uasyncio which avoids using hardware timers or interrupts. See
this doc and
code. This scales to any number of switches. Pushbutton objects also respond to long press and double-click events.
Posted: Wed Oct 03, 2018 10:02 am
by jedie
Thanks for feedback...
In the end i maybe use
https://github.com/peterhinch/micropython-async/ when I learn to use upip
I removed the timer usage and just debounce with
time.ticks_ms(), see:
Posted: Fri Dec 07, 2018 7:14 pm
by devxpy
Here is an implementation @dhylands was suggesting; it seems to be working quite well. (Thanks!)
It does, however, introduce jitter and inconsistencies in registering inputs when multiple buttons, and hence multiple `Timer`s are used, like @pythoncoder sugggested. Polling certainly works better for multiple buttons
P.S. How do I properly format text here? (It shows BBcode is OFF :/)
DEBOUNCE_MS = 10
class BtnCallback:
def __init__(self, pin, send):
self.pin = pin
self.timer = Timer(pin)
self._tmp = None
def on_timer_end(self, _):
if self.pin.value() == self._tmp:
print("pressed!")
self._tmp = None
def __call__(self, _):
if self._tmp is not None:
return
value = self.pin.value()
if not value: # no need for debounce on a button release
print("released!")
self._tmp = value
self.timer.init(
mode=Timer.ONE_SHOT,
period=DEBOUNCE_MS,
callback=self.on_timer_end,
pin = Pin(13, Pin.IN, Pin.PULL_UP)
pin.irq(handler=BtnCallback(pin))
Posted: Fri Dec 07, 2018 8:27 pm
by dhylands
The correct way to format the code is to surround it in a code block. BBCode will automagically get turned on for your account once you've made enough posts that moderation is no longer required.
