Hello every one !
Using the esp Luncher, I have a little issue. while developping, I as using my phone to test what happens on the client side. My cellular felt out of battery so I used, instead, my laptop whereas I didn't change anything.
Here's my code :
[code]
addr = socket.getaddrinfo('0.0.0.0', 80)[0][-1]
skt = socket.socket()
skt.bind(addr)
skt.listen(5)
htm = open('AskNWID.htm')
f_htm = htm.read()
cl, addr = skt.accept()
print('client connect from address ', addr)
query = cl.makefile('rwb', 0)
query = query.read(128)
query = query.decode('utf-8')[5:query.find(b'HTTP')]
print(query)
if query == 'data':
data = ""
data += ("<p>mode : %s" % (Mode.hardmode)) + "</p>\n"
data += ("<p>switch is %savailable") % "" if Mode._isAvailableDateReached() else "un"
elif 'RespNWID?' in query:
data, trash = query.split(b'?', 2)
SSID, PSWD = query.split(b'&', 2)
SSID = SSID[5:]
PSWD = PSWD[5:]
cl.send('OK')
print('analyzing data')
print(ussid, upswd)
elif len(query) == 1:
cl.send(f_htm)
time.sleep_ms(1000)
cl.close()
[/code] (sorry for BBCode, I can't turn it on. it is checked 'yes' on my profile preferences but anyway)
when trying to reach http://<IP>/ on my browser, it prints me 'connection reset' (translation from French 'connection réinitialisé').
when doing wget http://<IP>/ , it after 'HTTP request sent, waiting for response …"
But this is only from my laptop computer.
from my cellphone, my browser is able to print me the html page
however, using the 'terminal' termux on Android, a wget hangs after 'connecting to <IP> (<IP>:<PORT>)
So I assume my cellphone browser is able to deal with shaky socket communications But can you tell me what am I doing wrong.
You'll surely find many massive errors since I'm pretty new on python and even more with micropython.
thank's for your help !
