Using the GPIO0 /GPIO2 for OUTPUT and RX for INPUT
tonyldo
Post by tonyldo » Wed Jun 20, 2018 5:25 pm
how can i write this code with micropython?
void Setup() {
   Serial.begin(115200,SERIAL_8N1,SERIAL_TX_ONLY);
   pinMode(2, OUTPUT);
   pinMode(0, OUTPUT);
   pinMode(3, INPUT_PULLUP);
I will use on this circuit:
https://www.forward.com.au/pfod/ESP8266 ... UTPUTS.jpg
kevinkk525
Re: Using the GPIO0 /GPIO2 for OUTPUT and RX for INPUT
Post by kevinkk525 » Wed Jun 20, 2018 7:53 pm
You might want to have a look at the documentation: https://docs.micropython.org/en/latest/ ... /pins.html
What board are you trying to use?
Kevin Köck
tonyldo
Post by tonyldo » Thu Jun 21, 2018 12:29 am
kevinkk525 wrote: You might want to have a look at the documentation: https://docs.micropython.org/en/latest/ ... /pins.html
The documentation doesn't talk about the use of RX pin (gpio 3, esp01 module) as ordinary input pin and anything about disable the input serial comunication with something like this statement:
Serial.begin(115200, SERIAL_8N1, SERIAL_TX_ONLY);
Enviado de meu XT1580 usando o Tapatalk
tonyldo
Post by tonyldo » Thu Jun 21, 2018 3:26 pm
I'll test this in boot.py:
import uos, machine
TX_PIN = 1
uos.dupterm(none, 1)
uos.dupterm(machine.UART(0, 115200, pins=(TX_PIN, None)), 1)
and in main.py:
import  machine
RX_PIN = 3
pin = machine.Pin(RX_PIN , machine.Pin.IN, machine.Pin.PULL_UP)
newb
Post by newb » Sat Jul 28, 2018 4:17 pm
[quote=tonyldo post_id=28282 time=1529594788 user_id=4089]
[CODE]
import uos, machine
TX_PIN = 1
[/CODE]
and in main.py:
[CODE]
RX_PIN = 3
[/CODE]
[/quote]
Have you managed to solve this? I'm in the same situation - I'd like to use RX (pin 3) for button input, but it it doesn't work.
newb
Post by newb » Sat Jul 28, 2018 7:28 pm
Looks like I solved it myself.
Just needed to disable the UART:
https://github.com/micropython/micropyt ... 303fec6ed3
import uos
uart = machine.UART(0, 115200)
uos.dupterm(uart, 0)
And RX works as normal input pin :)
