flash directory corrupted with \x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00
HI,
working with v1.9.4-198-g25ae98f on ESP8266.
From time to time the above problem occurs.
I'm using asyncio and in one task log messages generated in other tasks with "uheapq.heappush(logQueue, ..." are written to a file named syslog.
If there are predefined number of lines in syslog, a new file (syslog.1) is created, all the content of syslog is copied to the new file except the first line. Then syslog is removed using uos.remove(syslog) and syslog.1 is renamed to syslog using uos.rename(syslog.1, syslog).
Following error message is shown in repl right after printing "nach rename":
Fatal exception 0(IllegalInstructionCause):
epc1=0x402773b4, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
The flash directory shows:
The instructions I use:
# wrap around syslog file if lines exceeds config.syslog_lines
lines = 0
for line in open('syslog', 'r'):
lines += 1
if lines >= config.SYSLOG_LINES:
with open('syslog', 'r') as f:
for i in range(lines - config.SYSLOG_LINES + 1):
line = f.readline()
with open('syslog.1', 'w') as output:
for line in f:
output.write(line)
print('vor remove')
uos.remove('syslog')
await asyncio.sleep(0.5)
print('vor rename')
uos.rename('syslog.1', 'syslog')
print('nach rename')
except OSError: # file not found
print('syslog not found')
pass
With insert of "await asyncio.sleep(0.5)" I tried to solve the problem. But unfortunately not.
Any help is highly welcome
Kurt
lines = 0
lines += 1
line = f.readline()
for line in f:
output.write(line)
print('vor remove')
print('vor rename')
pass
Kurt
Re: flash directory corrupted with \x00\x00\x00\x00\x00\x00\x00\x00.\x00\x00\x00
I get that problem sometimes if my unit reboots too often as it goes crazy sometimes when I connect it to my PC and just keeps booting over and over again.
Shouldn't be caused by your script, i think.
Kevin Köck
@kurt I don't really understand your code.
I'm not clear what that's supposed to do. More worryingly you've opened the file here (before opening it again in the context manager). I think the CM will open (and implicitly close) a second file handle, but the first will still be open. If I'm right you're then renaming an open file.
However this should raise an exception rather than cause a crash so you may have uncovered a MicroPython bug here.
[EDIT]
I tried renaming an open file on a Pyboard and it neither raised an exception nor crashed: the rename worked and the file handle continued to work too.
In practice the only way to track down a crash is progressively to reduce the program to a minimal test case which causes the crash to occur.
lines += 1
[EDIT]
HI,
many thanks for the answers.
After changing to:
lines = 0
for line in f:
lines += 1
print('lines read: ', lines)
line = f.readline()
for line in f:
output.write(line)
print('vor remove')
#await asyncio.sleep(0.5)
print('vor rename')
pass
Unfortnuately, the same error occurs.
It seems, the error happens only, when the wifi connection is established. I cannot understand, what the relation could be.
Many thanks for your help
Kurt
Update:
Free memory seems not to be the problem:
noumber lines in file: 10
mem_free before remove: 13616
mem_free before rename: 13040
mem_free after rename: 13040
mem_free before remove: 15072
After changing to:
lines = 0
for line in f:
lines += 1
line = f.readline()
for line in f:
output.write(line)
print('vor remove')
print('vor rename')
pass
Kurt
Update:
the problem can be recreated by flashing ESP8266 with the latest micropython build from micropython download page:
esp8266-20180511-v1.9.4.bin (elf, map) (latest)
using this small sketch:
let the sketch run till "number lines in syslog: 10" will shown more than one and interrupt then with ctrl c.
The error occurs not every time. After some attempts, I get:
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 31108, room 16
tail 4
chksum 0x28
load 0x3ffe8000, len 1100, room 4
tail 8
chksum 0x4e
load 0x3ffe8450, len 3268, room 0
tail 4
chksum 0x09
csum 0x09
l��|��rrnb��l�b�lb쌜���l�b�lrlll��|��rrnb��ll�lb�b쌜��b�b��lrl�l��|��rrnb��l��b�b쌜���b�lbl����n��r��n|�llll`b��|r�l�n��n�
ets_task(40100130, 3, 3fff83ec, 4)
OSError: [Errno 2] ENOENT
MicroPython v1.9.4-8-ga9a3caad0 on 2018-05-11; ESP module with ESP8266
and the directory is corrupted as mentioned in the first post.
Many thanks for any help.
Kurt
wlan_sta = network.WLAN(network.STA_IF)
wlan_sta.active(True)
wlan_sta.connect('SSID','PASSWORD')
while not wlan_sta.isconnected():
pass
lines = 0
with open('syslog', 'r') as f1:
for line in f1:
lines += 1
print('number lines in syslog: ', lines)
if lines >= 10:
with open('syslog', 'r') as f2:
for i in range(lines - 10 + 1):
line = f2.readline()
for line in f2:
output.write(line)
except OSError: # syslog not found
pass
with open('syslog', 'a') as f3:
f3.write('testdata\n')
tail 4
chksum 0x28
tail 8
chksum 0x4e
tail 4
chksum 0x09
csum 0x09
Kurt
Your code ran indefinitely on my hardware (the Adafruit Feather Huzzah reference board). If I arrange a counter so it runs N times before quitting it seems reliable.
However interrupting it with ctrl-C sometime causes an 'illegal instruction' crash and a corrupted filesystem. This seems to be a minimal testcase. First I create a file with this script:
Then I reboot and run this:
When I interrupt this with ctrl-C I get an illegal instruction crash. I have raised an issue.
with open('syslog', 'w') as f3:
for _ in range(10):
for line in f2:
output.write(line)
There is a separate issue: with recent builds I have seen corrupted filesystems with a lot of zeros immediately after a flash erase and install. This was fixed by using the very latest firmware, so I suggest you do likewise. Alas new firmware doesn't fix the above issue.
Hi Peter,
many thanks for your effort to help me.
Unfortunately, there is the same crash as before.
I flashed the latest daily build downloaded from http://micropython.org/download:
esp8266-20180625-v1.9.4-199-g6fc84a74.bin
Used uPyLoader to transfer your sketch into the flash:
After a short while the the following is shown without pressing ctrl-C key:
epc1=0x40276cb4, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
load 0x40100000, len 31048, room 16
tail 8
chksum 0xb6
load 0x3ffe8000, len 1092, room 0
tail 4
chksum 0xf2
load 0x3ffe8450, len 3252, room 4
tail 0
chksum 0x9b
csum 0x9b
����n�r��n|�llll`��r�l�l�l`��r�l�l�l`��r�l��
MicroPython v1.9.4-199-g6fc84a74 on 2018-06-25; ESP module with ESP8266
Also the flash directory is corupted as described above.
Don't know what could be wrong on my side.
My hardware is a similler version of the following:
https://www.exp-tech.de/en/platforms/in ... ed-esp8266
Regards
Kurt
for _ in range(10):
for line in f2:
output.write(line)
tail 8
chksum 0xb6
tail 4
chksum 0xf2
tail 0
chksum 0x9b
csum 0x9b
Regards
Kurt
If you revisit the issue I raised (and referenced above) you'll see that @Damien has acknowledged and diagnosed the bug. I'm sure it will be fixed shortly.
Hi Peter,
saw the fix of dpgeorge at your issue https://github.com/micropython/micropython/issues/3897 and tested it using esp8266-20180630-v1.9.4-227-gab02abe9.bin with code
which runs fine, without destroying the file directory.
But, if I run one time, do a hard reset, and then run this without doing a ctrl-C I get after a while:
epc1=0x40276fb4, epc2=0x00000000, epc3=0x00000000, excvaddr=0x00000000, depc=0x00000000
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
load 0x40100000, len 30904, room 16
tail 8
chksum 0x74
tail 4
chksum 0xdd
tail 0
chksum 0x94
csum 0x94
MicroPython v1.9.4-227-gab02abe9 on 2018-06-30; ESP module with ESP8266
Unfortunately, my problem is not yet fixed.
Regards
Kurt
for _ in range(10):
n = 0
for line in f2:
output.write(line)
n += 1
if n >= 20:
raise KeyboardInterrupt
But, if I run
for _ in range(10):
for line in f2:
output.write(line)
tail 8
chksum 0x74
tail 4
chksum 0xdd
tail 0
chksum 0x94
csum 0x94
Regards
Kurt
