Recovering from failure
My 8266 seems to hang after couple days. I couldn't replicate issue unless I put it in use (i.e. I cannot hook a computer to serial). I am wondering if there is any way to get a crash log? It doesn't seem that the problem was due to wifi as it seems to reconnect if I restart my router. Is it possible to have an external circuit to monitor failure (e.g. keep alive) and auto reset the device?
Re: Recovering from failure
I have a similar problem in this thread: viewtopic.php?f=16&t=4706&start=20
My esp8266 hangs after 1-2 weeks for 1h10 minutes, then recovers.
You could try a watchdog implementation (only software wdt using interrupts as the esp8266 does not have a hardware wdt):
You can easily adapt it to your environment by removing the log and the pysmartnode references (and asyncio if you don't use it).
import gc
import uasyncio as asyncio
from pysmartnode.utils import sys_vars
gc.collect()
from pysmartnode import logging
log = logging.getLogger("WDT")
class WDT:
def __init__(self, id=0, timeout=120):
self._timeout = timeout / 10
self._counter = 0
self._timer = machine.Timer(id)
self.init()
asyncio.get_event_loop().create_task(self._resetCounter())
if sys_vars.hasFilesystem():
with open("watchdog.txt", "r") as f:
if f.read() == "True":
log.warn("Reset reason: Watchdog")
except Exception as e:
print(e) # file probably just does not exist
with open("watchdog.txt", "w") as f:
f.write("False")
log.error("Error saving to file: {!s}".format(e))
def _wdt(self, t):
self._counter += self._timeout
if self._counter >= self._timeout * 10:
f.write("True")
print("Error saving to file: {!s}".format(e))
machine.reset()
def feed(self):
self._counter = 0
def init(self, timeout=None):
timeout = timeout or self._timeout
self._timer.init(period=int(self._timeout * 1000), mode=machine.Timer.PERIODIC, callback=self._wdt)
def deinit(self): # will not stop coroutine
self._timer.deinit()
async def _resetCounter(self):
await asyncio.sleep(self._timeout)
self.feed()
Kevin Köck
For a software watchdog with uasyncio you could look at this module. This has a Delay_ms class. This will trigger a callback if it is not repeatedly triggered.
The ultimate solution is a hardware watchdog. A retriggerable monostable is repeatedly retriggered by a software-generated puls on a pin. It activates the hardware reset if it times out. The key advantage is that the system will recover from a total crash where the CPU stops running code.
