unable to revert to main filesystem
philwilkinson40
Post by philwilkinson40 » Sun Jul 08, 2018 2:09 am
I am running a uSD card shield on a esp8266 devboard
I am able to mount the SD card using
import machine, sdcard, os
sd = sdcard.SDCard(machine.SPI(1), machine.Pin(15))
os.umount('/')
vfs=os.VfsFat(sd)
os.mount(vfs, '/sd')
os.listdir()
I can then open and append files in the /sd directory. However I can't revert back to the main filesystem using
import flashbdev
os.umount()
os.VfsFat(flashbdev.bdev)
which returns MemoryError: memory allocation failed.
I am not sure I am using VfsFat correctly.
Any ideas?
yeyeto2788
Re: unable to revert to main filesystem
Post by yeyeto2788 » Mon Aug 13, 2018 10:59 am
Have you tried something like this:
os.chdir("/")
I guess that once you mount the filesystem if you do a `os.getcwd()` it will return the mounted volume (not sure).
I would just try that out to see if it works.
Regards.
Post by OutoftheBOTS_ » Mon Aug 13, 2018 9:27 pm
I do believe that u find files on sd card in "/sd/" and files on the flash in "/flash/"
so
os.chdir("/flash")
should get you to the flash file system
and
os.chdir("/sd")
will then get you back to the sd file system
yeyeto2788
Post by yeyeto2788 » Tue Aug 14, 2018 6:02 pm
I haven't tested yet but I guess that changing directory should work. Have you tried it?
I reply to the post to see if that could help you out, my thoughts were that when you mount the SD card the current working directory would be the SD that's why I supposed that with os.chdir() would do the trick. :(
