Maximum possible machine.Timer period
neurino
Post by neurino » Wed Aug 08, 2018 8:22 am
I'm new to the forum, thanks for such a beautiful development platform!
What is the maximum period I can set for a Timer?
I set it carelessly to 6 hours — 1000 * 60 * 60 * 6 == 21600000 — and from server access logs it's seems it's not being called at all.
Here the code:
period = 21600000
timer = machine.Timer(-1)
timer.init(period=period,
callback=lambda timer:
micropython.schedule(timer_cb, timer),
mode=machine.Timer.PERIODIC)
It works with shorter intervals like 60000 (1min)
P.S.: no code formatting allowed to me? Well, luckily I can spam as many smiles as I want :D :) ;) :( :o :shock: :? 8-) :lol: :x :P :oops: :cry: :evil: :twisted: :roll: :!: :?: :idea: :arrow: :| :mrgreen: :geek: :ugeek:
neurino
Re: Maximum possible machine.Timer period
Post by neurino » Thu Aug 30, 2018 10:54 am
Bump!
So no one's interested in a working Timer on spans bigger than 1 minute? :)
jickster
Post by jickster » Thu Aug 30, 2018 6:42 pm
neurino wrote:Bump!
What hardware are you using?
jickster
Post by jickster » Thu Aug 30, 2018 9:12 pm
Here the code:
period = 21600000
I don't know why it's failing. You are able to set up to a maximum of UINT32 so a value of 21 million should be ok.
Try setting the period to 65536. which is one bigger than a UINT16.
If that doesn't fail, keep increasing it until you reach the point it does fail.
Let me know (by quoting this post).
neurino
Post by neurino » Mon Sep 03, 2018 4:15 pm
Here the code:
period = 21600000
It's somewhere between 120000 (gets called) and 480000 (NOT called).
I hope I can avoid trying to find the exact threshold :)
Here the code:
import micropython
def timer_cb(timer):
  print('here', timer)
period = 480000
  callback=lambda timer: micropython.schedule(timer_cb, timer),
jickster
Post by jickster » Mon Sep 03, 2018 10:20 pm
Here the code:
period = 21600000
Here the code:
import micropython
period = 480000
Those numbers don't stand out to me.
I think something else is going on.
Do you have access to a C-debugger?
neurino
Post by neurino » Tue Sep 04, 2018 3:30 pm
Sorry, no debugger,
haven't anyone out there been able to reproduce the issue?
I mean someone with an ESP8266 ruing these few lines and seeing if he gets timer_cb called or not after 6 minutes (480000ms)
import micropython
period = 480000
On my side, I started relying on a DS3231 alarm to trigger my hourly job, however getting this fixed would really help in other projects.
jickster
Post by jickster » Tue Sep 04, 2018 3:43 pm
Sorry, no debugger,
import micropython
period = 480000
Why are you using .schedule?
neurino
Post by neurino » Tue Sep 04, 2018 4:17 pm
Simply because I read it here: https://docs.micropython.org/en/latest/ ... rules.html
* Avoid memory allocation: no appending to lists or insertion into dictionaries, no floating point.
* Consider using micropython.schedule to work around the above constraint.
etc
