[SOLVED] import module from filesystem
yeyeto2788
Post by yeyeto2788 » Wed Aug 08, 2018 1:46 pm
Hello guys,
I'm currently working on a project that involve importing selected modules (https://github.com/yeyeto2788/MicroPythonScripts) that are already in the filesystem.
So let's say I have my script call `menu.py` and it will get all files on the filesystem and if I select one of them I want that module to be executed.
Files in the filesystem:
  • menu.py
  • boot.py
  • test.py
  • abs.py
This is the code on the `menu.py` to get the files and try to import the module from the filesystem:
import time,  os
def get_files():
    extensions = ".py"
    excluded_files = ["main.py", "boot.py"]
    dirfiles = []
    for filename in os.listdir():
        if filename.lower().endswith(extensions):
            if filename.lower() not in excluded_files:
                dirfiles.append(filename.replace(extensions, ""))
    return dirfiles
a = get_files()[1]
import a
a.show()
So this function will give the `test.py` and the `abs.py` and import the `test.py` script and execute the function `show()` on it which is simply prints a string:
print("wujuuuu imported!")
I get an error saying the following:
 b'Traceback (most recent call last):\r\n  File "<stdin>", line 12, in <module>\r\nImportError: no module named \'a\'\r\n')
Is there any possible solution for this? or anyone that could help me out with this?
Christian Walther
Re: import module from filesystem
Post by Christian Walther » Wed Aug 08, 2018 4:39 pm
The import statement takes a name, not an expression. You want the __import__ function (ignore the reference to importlib, it doesn’t exist on MicroPython).
See https://github.com/pewpew-game/pewpew/b ... es/menu.py for a working example of the exact thing you want to do. It’s in CircuitPython, but the relevant part (last few lines) translates to MicroPython unchanged.
yeyeto2788
Post by yeyeto2788 » Mon Aug 13, 2018 10:39 am
Wujuuuu! It worked like a charm :D .
Thank you very much for the help!
Regards.
untitled
Re: [SOLVED] import module from filesystem
Post by untitled » Thu Dec 12, 2019 5:28 pm
That link returns 404 now.
Could someone please share a working solution?
Christian Walther
Post by Christian Walther » Fri Dec 13, 2019 12:06 pm
If you’re referring to the PewPew menu.py link, that has moved to https://github.com/pewpew-game/game-men ... er/main.py.
