[SOLVED]cannot connect relay module
atux_null
Post by atux_null » Wed Aug 08, 2018 2:27 pm
hi. i a taking my baby steps with micropython and esp8266 nodemcu. i am trying to connect a relay and play with it.Image and i have a 9V battery and a led connected. the circuit is:
-a cable from the + side of the battery goes to the middle of the relay (C)
-a cable from the NO of the relay goes to one leg of the led.
-a cable from the - side of the battery goes to the other leg of the led.
Once everything is connected i see the led to be switched on.
the pin used in ESP8266 nodemcu to connect to is the D1.
then i issue on the repl:
relay = Pin(5, Pin.OUT)
relay.value(0) # to switch it off
relay.value(1) # to switch it on
the problem is that the led statys always on and the onboard led(red) of the relay is always on. Also i do not hear a click as it is supposed to be when changing state.
thanks in advance.
yeyeto2788
Re: cannot connect relay module
Post by yeyeto2788 » Wed Aug 08, 2018 2:43 pm
Try adding a delay between on and off to see if it's doing what is supposed to do.
What could be happening is that the pin changes its state (from on to off and vice-versa) so quick that you might not be seeing the led to go off or hearing the relay being activated/deactivated.
try something like this:
time.sleep(2)
Note the `time.sleep(2)` which will hang for 2 secs.
P.D: Hope it helps!
atux_null
Post by atux_null » Wed Aug 08, 2018 2:55 pm
no changes at all. :?
yeyeto2788
Post by yeyeto2788 » Wed Aug 08, 2018 7:46 pm
Are you sure the relay is 3.3 volts compatible? Is it active low or active high? If it is active low try connecting it to GND directly.
Also take into account that you should have all GND (relay and esp8266 GND) connected together.
I don't really see anything wrong on the code side, so it might be hardware related.
atux_null
Post by atux_null » Thu Aug 09, 2018 4:34 pm
solved. instead of vin i had to connect to 3.3v pin.
Thanks a lot.
yeyeto2788
Post by yeyeto2788 » Mon Aug 13, 2018 10:39 am
No problem! Glad you got it working. :D
You might consider changing the name of the Post adding a [SOLVED] at the beginning.
Regards.
Sniper
Post by Sniper » Tue Feb 11, 2020 9:53 pm
time.sleep(2)
P.D: Hope it helps!
I get this output in micropython
>>> from machine import Pin
ImportError: cannot import name Pin
Re: [SOLVED]cannot connect relay module
Post by Roberthh » Wed Feb 12, 2020 9:13 pm
Which module are you using? Really ESP8266? And are you sure that you are talking to that device?
