Custom modules in v1.9.4-443 firmware now boot.py and main.py won't load
Re: Custom modules in v1.9.4-443 firmware now boot.py and main.py won't load
Post by Roberthh » Tue Oct 30, 2018 8:40 pm
That's strange. In REPL, when you execute the commands:
import uos
uos.listdir()
Does the list of files show boot.py?
krekos
Post by krekos » Tue Oct 30, 2018 9:21 pm
OK. my mistake. when i upload boot.py with example blinking LED it worked. So i start to debuging my boot.py and it seams i have some bug in it.
But i dont saw it because with my firmware, when i use print() it didnt print into console for some reason.
But main probmlem with boot.py seams to be gone now.
kevinkk525
Post by kevinkk525 » Wed Oct 31, 2018 9:34 am
I did add the line "import main" into _boot.py in modules directory. This way I can freeze the main.py too.
"boot.py" is not imported though.
BOB63
Post by BOB63 » Mon Nov 05, 2018 9:17 am
Hi ,
I'm facing the same problem of no REPL after have compiled the firmware ( see post viewtopic.php?f=16&t=5490).
In my case the issue is present also if I compile the firmware w/o add any frozen module.
PYB: soft reboot
Activated UART(0) for REPL
MicroPython v1.9.4-683-gd94aa57 on 2018-11-05; ESP module with ESP8266
This is the boot.py :
# This file is executed on every boot (including wake-boot from deepsleep)
import esp
esp.osdebug(None)
import gc
import webrepl
webrepl.start()
gc.collect()
and this is the content of the two directory where the firmware modules are stored :
During the compilation of firmware I don't have any error so I've not idea at all wher could be the issue.
Cattura freez.JPG (131.72 KiB) Viewed 122 times
Thanks. Roberto
