From two addresses, get distance and route summary - using google api.
fangis
Post by fangis » Sat Aug 11, 2018 12:19 am
Hi
This script uses google api,
it gets two addresses as input and retrieves the distance in Km and a summary of the route.
It is started by the start() function.
import socket
def start():
    found = 0
    origem = input("origem:")
    origem = origem.replace(" ",",")
    destino = input("destino:")
    destino = destino.replace(" ",",")
    a = socket.getaddrinfo("googleapis.com", 80)
    a = a[0][-1]
    s = socket.socket()
    s.connect(a)
    s.sendall("GET /maps/api/directions/json?origin=")
    s.sendall(origem)
    s.sendall("&destination=")
    s.sendall(destino)
    s.sendall("&sensor=false")
    s.sendall("\r\n\r\n")
        linha = str(s.readline(), 'utf8')
        if "km" in linha:
          if found == 1: continue
          print(linha.split('"')[3])
          found = 1
        elif "ummary" in linha:
          s.close()
          break
      except:
        print("Exception.\r\n")
        s.close()
        break
The script usually works. However, for bigger distances, the large reply by google api causes a memory error and the exception gets called.
A simpler way using urequests is what I have tried first, but it gets even more memory errors.
Do you know how to improve the code and make it work? If so, please show it.
thanks
Re: From two addresses, get distance and route summary - using google api.
Post by pythoncoder » Sat Aug 11, 2018 3:44 am
I would try forcing a garbage collect on each iteration of the loop:
import socket
import gc
# code omitted
      gc.collect()
fangis
Post by fangis » Sat Aug 11, 2018 11:48 pm
Thanks for the reply, pythoncoder.
I tried it and it seemed to work, but then I realized I was still getting the exceptions sometimes.
I started to wonder, and was even going to ask you, what really cause these memory errors since the data is being sent line by line, how then would this possibly flood the memory? Then I thought, maybe one single line is causing the error. This seemed to be the answer.
It seems some of the lines sent by google are quite large, possibly causing the crashes.
I searched more about the readline method and found that I can do the following:
s.readline(200)
which has made the script much more stable! it's now working even without the gc collect.
