IR 38Khz frequency out
pmulvey
Post by pmulvey » Wed Aug 15, 2018 9:05 am
The Arduino (ATMega 328) has a timer register that can be preloaded and set to pulse an I/O pin on overflow so that a 38KHz output waveform is generated outside of program control. Has the ESP8266 anything like this? Bit banging with micropython is not fast enough I'm sure.
Paul Mulvey
Re: IR 38Khz frequency out
Post by pythoncoder » Wed Aug 15, 2018 9:19 am
I have doubts whether the ESP8266 could do this as it's prone to latency issues and the frequency needs to be quite stable. But you could experiment.
The Pyboard should cope easily.
mcauser
Post by mcauser » Wed Aug 15, 2018 11:44 am
I haven’t tried it but hotplot on github says you can generate a 38 kHz signal in hardware by configuring the MTMS pin as the I2S clock signal and setting the frequency appropriately.
Platformio code example here:
https://github.com/hotplot/BlastIR/blob ... r_send.cpp
Post by pythoncoder » Thu Aug 16, 2018 8:16 am
Clever ;) I'd go with that solution.
pmulvey
Post by pmulvey » Thu Aug 16, 2018 11:08 am
Has anyone implemented this method in micropython?
Paul Mulvey
Zolee
Post by Zolee » Thu Mar 28, 2019 7:41 pm
Arduino code for esp8266:
https://github.com/markszabo/IRremoteESP8266
Tested with wemos d1 mini. It works!
Pottiepie
Post by Pottiepie » Mon Sep 02, 2019 4:16 pm
Yes the Arduino libraries works with my NodeMCU. Has it been ported to Micropython? This is the only thing stopping from me from switching over as I need IR to control my fan and aircon
