problem with Wemos D1 mini
hi guys,
I try to connect serial Wemos D1 mini with Coolterm but while I start connect and press reset button, the window of Coolterm displays as below
slpónà....ƒ.d......c.nă|.́Œdd„.cŒûooç.dŒl`.˜..oo.l`...o{““g..›.d`.xógà....sŒœœăà....c.gă|.dd..cŒûonç...l`...gg.l`...ns‡’’o..ƒ.œ.dpûoà....rŒœœăà.s€.c.oă|.́....c„óggï...d`.˜..oo.d`...o{›“n..‚Œ.l.s“’g..ƒ„.d.ü€.lœŸ|₫ƒ.r{oc„.ĺ...b́l.ć„œœăă.Œ..c.l{d„ậ“x.ƒno€l.ll...lć.....l`.sl.dœ|.Œlà|....Œ.lä.b|‡ƒ.́.›s“cŒ.cŒûnnlgoœắ.b.xŒ‡lslrlx̣gà....ƒ.l......c.oâ|.ä„llŒ.c„óngï.lŒd`...ng.l`...ns‡’’o..“.l`.pûoà....rŒœœăà....c.oă|.ll..c„óggï...d`.˜..oo.d`...g{›“n..‚.œ.lpógà....{„œœăà.‡r€.b.gă|.́....cŒûooç...l`...ng.l`...ns“’g..ƒ„.d.r››o..ƒŒ‡.l.ü€.lœŸ|ÿƒ.r{ocŒ.ĺ...b́l.ć„œœăă.Œ..c.l{d„âû“x.ƒno€l.ll...l‡ć.....l`.sl.dœ|.Œlà|....Œ.lä.b|‡‚.́.›s“cŒ.c„ónglooœắ.c.xŒ‡lslrdx̣gà....ƒ.l......c.oâ|.äŒllŒ.c„óngï.lŒd`...gg.l`...ns‡’’o..“.l`.pûoà....rŒœœăà....c.oă|.ll..c„óggï...d`.˜..oo.d`...o{›“n..‚.œ.lpógà....s„œœăà.‡{€.b.gă|.́....cŒûooç...l`...ng.l`...ns‡“’o..ƒ„.d.{››n..‚Œ‡.l.ü€.dœ|ÿ‚.{{nbŒ.lä...ćl.cä„œœăă.Œ..b.lslŒăû’p.ƒgn€l.dd...l‡cä.....l`.sl.lœŸ|.„là|....Œ.dä.c|‡ƒ.ä.“s’bŒ.c„óggŸlooœăä.c.pŒdrl{dxûoà....‚.l......c.oă|.́ŒllŒ.bŒóggî.d„l`...go.d`...gr››o..“.l`.pónà....{„œœăà....c.nă|.ll..bŒ̣ooî...l`...on.l`...o{““g..ƒ.œ.lx̣gà....sŒœœâà.{€.c.oâ|.ä....cŒûnnï...l`...gg.l`...gs‡’›o..ƒŒ‡.l.{““g..ƒŒ.l.ü€.lœŸ|ÿƒ.srgc‡„.ĺ...cäd.ćŒœœăâ.Œ..c.drdŒăó“p.ƒog€d.ll...dć‡.....l`.{l.lœŸ|.Œdà|....Œ.ĺ.c|ƒ.́.›{›cŒ.cŒûooŸlggœấ.c.pŒl{lslpógà....ƒ.l......b.gă|.́„ddŒ.cŒûonç.lŒ‡l`...on.l`...os““g..›.d`.x̣oà....sŒœœâà....c.oâ|.dl..‡c„óngï...l`...gg.d`...gr‡››o..ƒ.œ.lpûnà....{„œœăà.‡s€.c.nă|.́....bŒ̣goî...l`.˜..on.l`...o{““g..ƒ„.l.s’›o..ƒŒ.l.ü€.lœŸ|ÿƒ.srgc‡„.ĺ...cäd.ćŒœœăâ.Œ..c.drdŒăó“p.ƒog€d.ll...dć‡.....l`.{d.lœŸ|.Œdà|....Œ.ĺ.c|ƒ.́.›{›c„.cŒûooŸlggœấ.c.pŒl{lslpógà....ƒ.l......b.gă|.́„ddŒ.cŒûonç.lŒ‡l`...on.l`...os““g..›.d`.x̣gà....sŒœœâà....c.oâ|.dl..‡c„ónnï...l`...gg.d`...gr‡››o..ƒ.œ.lpûnà....{„œœăà.‡s€.c.nă|.́....bŒ̣goî...l`.˜..oo.l`...o{““g..ƒ„.l.s’›o..ƒŒ.l.ü€.lœŸ|ÿƒ.srgc‡„.d́...cäd.ćŒœœăâ.Œ..c.drlŒăó“p.ƒog€d.ll...dć‡.....l`.{d.lœŸ|.Œdà|....Œ.ĺ.c|ƒ.́.›{›c„.cŒûooŸlggœấ.c.pŒl{lslpógà....ƒ.l......b.gă|.́„ddŒ.cŒûonç.lŒ‡l`...on.l`...o{““g..›.d`.x̣gà....sŒœœâà....c.oâ|.dl..‡c„ûnnï...l`...gg.l`...gr‡’›o..ƒ.œ.lpûoà....{Œœœăà.s€.c.nă|.́....bŒ̣goî...l`.˜..oo.l`...o{““g..ƒ„.l.s’›o..ƒŒ.d.ü€.lœŸ|₫ƒ.sroc„.ĺ...cäl.ćŒœœăâ.Œ..c.drd„ặ“x.ƒoo€l.ll...dć‡.....l`.{l.dœŸ|.Œdà|....Œ.ĺ.c|ƒ.́.›{“cŒ.cŒûonŸlggœấ.b.xŒ‡lslslpógà....ƒ.l......b.gă|.ä„dlŒ.cŒûnnï.lŒ‡l`...nn.l`...os“’g..›.l`.x̣oà....sŒœœâà....c.oă|.dl..‡c„óngï...d`...go.d`...gr››o..ƒ.œ.lpónà....{„œœăà.‡r€.c.nă|.́....cŒ̣ooç...l`...on.l`...os““g..ƒ„.d.r’›o..ƒŒ‡.l.ü€.lœŸ|ÿƒ.r{ocŒ.ĺ...b́l.ć„œœăă.Œ..c.l{d„âû“x.ƒno€l.ld...l‡ć.....l`.sl.dœ|.Œlà|....Œ.lä.b|‡‚.́.“s“cŒ.c„ónglooœắ.c.xŒ‡lslrdx̣oà....ƒ.l......c.oâ|.äŒllŒ.c„óggï.lŒd`...gg.l`...ns‡’›o..“.l`.pûoà....rŒœœăà....c.oă|.ll..b„óggî...d`.˜..oo.d`...o{›“n..‚.œ.lpógà....s„œœăà.‡{€.b.gă|.ä....cŒûooç...l`...ng.l`...ns‡“’o..ƒ„.d.{››n..‚Œ‡.l.ü€.dœ|ÿ‚.{snbŒ.lä...ćl.c䌜œăă.„..b.‡lslŒăû›p.ƒgn€l.dd...l‡cä.....l`.sl.lœŸ|.„là|....Œ.dä.c|ƒ.ä.“s’bŒ.c„óggŸlonœăä.c.pŒdrd{dpûoà....‚.l......c.oă|.́Œll„.bŒógoî.d„l`...go.d`...gr››o..“.l`.pónà....{„œœăà....c.nă|.ll..cŒ̣ooç...l`...on.l`...os““g..ƒ.œ.dx̣gà....sŒœœâà.{€.c.oâ|.ä....c„ónnï...l`...gg.d`...gr‡››o..ƒŒ‡.l.{““g..ƒ„.l.ü€.lœŸ|ÿƒ.ssgc‡„.d́...cäd.ćŒœœăâ.Œ..c.drlŒăó“p.ƒog€d.ll...dć‡.....d`.{d.lœŸ|.Œdà|....Œ.ĺ.c|ƒ.́.›{›c„.cŒûooŸdggœấ.c.pŒl{lslpógà....ƒ.d......b.gă|.́„ddŒ.cŒûooç.lŒ‡l`...on.l`...o{““g..›.d`.x̣gà....sŒœœâà....c.oâ|.dd..‡cŒûnnï...l`...gg.l`...gs‡’›o..ƒ.œ.lpûoà....{Œœœăà.s€.c.nă|.́....bŒógoî...d`.˜..oo.l`...o{““g..ƒŒ.l.s’’o..ƒŒ.d.ü€.lœŸ|ÿƒ.r{ocŒ.ĺ...b́l.ć„œœăă.Œ..c.l{d„âû“x.ƒno€l.ll...lć.....l`.sl.dœ|.Œlà|....Œ.lä.b|‡‚.́.›
Besides, led on Wemos D1 mini blinks permanently.
Could anyone help me?
thanks
thanks
Re: problem with Wemos D1 mini
During boot, the device send data at a different baud rate, like 76800 baud. You can set PuTTY Windows to that baud rate. But that gibberish phase should be short. If it goes on and on, the maybe the firmware image is missing. Butt looking at the messages might help.
Thank for your help, actually I flash this Wemos with baudrate 115200 and my Coolterm or PuTTY also set 115200. I also try with others baudrate and receive the same problem.
How did you flash the device?
I follow this tutorial
https://www.youtube.com/watch?v=yVU1wdHwIlQ
The device is flashed by NODEMCU Firmware programmer
Sorry, I'm more the reading than the video person. Which command did you use to flash the firmware? It must use the program esptool.py.
I download firmware from micropython.org and flash by ESP8266Flasher (NODEMCU FIRMWARE PROGRAMMER)
Do you have other tutorial to use micropython for Wenos D1 mini
You can use esptool.py from the command line:
esptool.py --port <PORT> --baud 115200 write_flash --verify --flash_size=4MB --flash_mode=qio 0 <image_file>
flash_mode may also be dio.
esptool.py is e.g. at: https://github.com/espressif/esptool/bl ... esptool.py
Which IDE I can use?
For image flashing? No IDE
For using Python on the ESP8266: There is no dedicated IDE. Some people use pycharm. Other prefer more a command line version like rshell. To some extend, the pymakr plugin for Atom or VSC of Pycom may work.
Did you manage to install the firmware and get you device running?
