Dear Community;
I am trying to transfer data using usocket module. I want to transfer data from ESP8266 to my computer. So in my computer I am running this python script:
import socket # Import socket module
s = socket.socket() # Create a socket object
host = socket.gethostname() # Get local machine name
port = 12345 # Reserve a port for your service.
s.bind(('localhost', port)) # Bind to the port
s.listen(5) # Now wait for client connection.
c, addr = s.accept() # Establish connection with client.
print 'Got connection from', addr
l = c.recv(1024)
while (l):
print "Receiving..." +str(l)
f = open('receive.txt','a')
f.write(l + '\n')
l = c.recv(1024)
f.close()
print "Done Receiving"
c.send('Thank you for connecting')
c.close()
f.close()
In the ESP8266 I want to run a script that I have tested on another computer. But it appears that due to usocket limitations it is not compatible: This is the code:
import usocket as socket # Import socket module
s.connect(('localhost', port))
s.send("Hello server, I am sending data!")
print 'Data Sent'
The problem is that in the line s.connect(('localhost', port)) I get this error:
ValueError: invalid arguments
It appears that I can not specify the port. So please how can I do this?
Thanks in advance;
Ander.
Usocket port in ESP8266
Re: Usocket port in ESP8266
I have found a solution, by code was WRONG completely.
Server:
#!/usr/bin/env python3
from socket import socket, gethostbyname, AF_INET, SOCK_DGRAM
PORT_NUMBER = 12345
SIZE = 1024
hostName = gethostbyname( '0.0.0.0' )
mySocket = socket( AF_INET, SOCK_DGRAM )
mySocket.bind( (hostName, PORT_NUMBER) )
print ("Test server listening on port {0}\n".format(PORT_NUMBER))
(data,addr) = mySocket.recvfrom(SIZE)
print data
time.sleep(.05)
ESP8266:
from socket import socket, AF_INET, SOCK_DGRAM
SERVER_IP = '192.168.1.60'
PORT_NUMBER = 12345
SIZE = 1024
print ("Test client sending packets to IP {0}, via port {1}\n".format(SERVER_IP, PORT_NUMBER))
myMessage = "Hello; I am transmiting data!"
mySocket.sendto(myMessage.encode('utf-8'),(SERVER_IP,PORT_NUMBER))
Server:
PORT_NUMBER = 12345
SIZE = 1024
print data
time.sleep(.05)
ESP8266:
PORT_NUMBER = 12345
SIZE = 1024
Your first version wasn't completely wrong, it just used the wrong arguments to connect().See the documentation on how to do it correctly (section "Socket address format(s)":
http://docs.micropython.org/en/latest/e ... ocket.html
You second version works rather differently than the frst one. It uses UDP instead of TCP and is thus inherently less reliable due to no protection against packet loss.
Thank you for your answer. I will try to use TCP instead of UDP. However, UDP protocol works perfectly.SpotlightKid wrote: ↑Fri Sep 28, 2018 9:26 amYour first version wasn't completely wrong, it just used the wrong arguments to connect().See the documentation on how to do it correctly (section "Socket address format(s)":
As long as you're on a local network, UDP usually works fine. The problem is, that the recipient can't know whether it missed any packets. So if you're sending files, you should at least send some sort of checksum along with it, so the recipient can verify the transmission.
