esp8266 won't wake from sleep
wipity
Post by wipity » Sat Sep 29, 2018 1:03 pm
I have an esp8266 running micropython v1.9.3 , I'm trying to work with the deep sleep and it work, but also if I have a connection between reset and GPIO16, using the script like the example in the documentation, the chip go in sleep mode but I can wake it only with a reset to gnd.
Seems alarm0 don't work properly.
what is wrong?
thanks
ad525
Re: esp8266 won't wake from sleep
Post by ad525 » Sat Sep 29, 2018 2:59 pm
Hello, please post the code to see what can go wrong :D
wipity
Post by wipity » Sat Sep 29, 2018 5:25 pm
this one from the documentation:
# configure RTC.ALARM0 to be able to wake the device
rtc = machine.RTC()
rtc.irq(trigger=rtc.ALARM0, wake=machine.DEEPSLEEP)
# set RTC.ALARM0 to fire after 10 seconds (waking the device)
rtc.alarm(rtc.ALARM0, 10000)
# put the device to sleep
machine.deepsleep()
wipity
Post by wipity » Sat Sep 29, 2018 5:28 pm
I disconnect gpio16 when I flash and reconnect after flashing.
when I use this script the device go to sleep but wake up only with manual reset
Post by pythoncoder » Tue Oct 02, 2018 11:06 am
How are you checking for the awake message? If you're connected via USB it's very likely that the USB interface remains down after the board wakes. I would expect the code sample only to work on a serial connected device (e.g Adafruit Huzzah rather than the Feather series).
wipity
Post by wipity » Wed Oct 03, 2018 6:48 am
Ho,
I have a led to a gpio that turn on for ten seconds in the main.py file after boot file, after this time start a script with the sleep function, so if the awake do a reset, I believe I can see the led on after wake, but it turn on only if I do a manual reset.
I’m using an esp8266 with a usb to serial, not a board, but it’s the same .
There’s maybe some issue in firmware version?
After the flash i connect gpio 16 to rst pin ( i have 10 sec to do it!) , the device go in sleep ( i can see with serial garbage after the print message in the script, but the led stay off.
wipity
Re: esp8266 won't wake from sleep[SOLVED]
Post by wipity » Fri Oct 12, 2018 5:15 pm
I’ve found the problem: power source.
I’m using esp8266 only with resistor and cap and with an external usbtoserial converter, no nodemcu or huzzah board.
When I power device with a strong power source and not from vcc of usb, wake normally, and it’s no problem, I can see the serial message anywhere.
ambob
Post by ambob » Wed Oct 31, 2018 1:05 am
hi
I have this problem too
change power source did not solve it
use usb power or battery power it will not wake up too
ambob
Post by ambob » Fri Nov 02, 2018 12:09 am
抱歉 我的英文是如此的匮乏,表达不来下面的意思
之前,我在程序启动时候初始化rtc 然后设置关于deepsleep的参数
rtc.alarm(rtc.ALARM0, deep_sleep_time)
这种情况下,在进入deepsleep之后不会醒来
但是当我把上面两行放到了程序结尾,在他后面就是
machine.deepsleep()
他顺利的工作了
