I have encounter a problem trying to make a script that just checks the price for bitcoins the code is the following:
from console import Display
import urequests
import json
#import gc
oled = Display()
def ConnectWifi(SSID, pwd):
Function to connect to WIFI.
Args:
SSID: String with the name of the WIFI connection.
pwd: String with the WiFi password.
Returns: True if it's connected to wifi
if not sta_if.isconnected():
oled.clear(0, 1)
oled.print_wrapped('Connecting to network...')
time.sleep(1)
sta_if.active(True)
sta_if.connect(SSID, pwd)
pass
def GetTime():
Get local time from the internet.
Returns: Nothing
import ntptime
ntptime.settime()
ts = time.localtime()
year = ts[0]
Month = ts[1]
day = ts[2]
hour = ts[3]
mins = ts[4]
dayYear = ts[7]
ActualTime = "%s/%s/%s %s:%s" % (str(day), str(Month), str(year), str(hour), str(mins))
return ActualTime
SSID = "SSIDName"
pwd = "SSIDPassword"
#print("Free out: " + str(gc.mem_free()))
r = urequests.get("https://api.coindesk.com/v1/bpi/currentprice/EUR.json")
Data = r.json()
USD = Data["bpi"]["USD"]["rate_float"]
EUR = Data["bpi"]["EUR"]["rate_float"]
Date = Data["time"]["updated"]
oled.clear(0, 1)
oled.print_on_line("Price from %s" % Date.split(",")[0], 0)
oled.print_on_line(str(Date.split(",")[1].lstrip()))
oled.print_on_line("USD: %s" % str(USD), 2)
oled.print_on_line("EUR: %s" % str(EUR), 3)
time.sleep(10)
>>> import bitcoin_price
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 31108, room 16
tail 4
chksum 0x28
load 0x3ffe8000, len 1100, room 4
tail 8
chksum 0x4e
load 0x3ffe8450, len 3268, room 0
tail 4
chksum 0x09
csum 0x09
$▒▒|▒▒2rrnc▒▒▒
l▒
B▒ܜ▒▒
▒#l`ll▒▒|▒▒so"▒▒▒ll▒l
#▒▒c䌜▒▒b▒
c▒
▒l{$▒l▒▒|▒▒{ob▒▒▒l▒▒b▒
#▒ܜ▒▒b▒$cl▒▒▒N▒{▒▒o|▒
$ld`b▒▒|r▒l▒n▒▒n▒
d`▒▒{▒l▒$2▒
l ▒▒{▒l▒$
l ▒▒{▒p▒
$l {l▒▒▒c▒▒▒c
▒▒#|lc▒▒b|▒▒▒▒
dlc▒▒o▒2Nn▒▒$n▒▒▒▒$▒ld▒▒▒
$`▒o▒▒▒▒cBl$섏▒
c▒▒▒#l▒#r$rdr▒o▒▒▒
▒2c{#▒▒"▒b▒▒cl▒p▒▒s"
▒"▒▒n▒߀▒c{#▒▒"▒b▒▒cd▒
B▒▒{bl ▒l▒▒▒▒▒rNc▒▒▒▒▒▒
▒c▒
b䌜▒▒|▒▒
#l$cl▒▒lo▒l ▒▒lo▒p{l▒$ܞ|▒2▒▒rn#▒▒▒▒▒▒r▒#▒▒#5 ets_task(40100130, 3, 3fff83ec, 4)
OSError: [Errno 2] ENOENT
MicroPython v1.9.4-8-ga9a3caad0 on 2018-05-11; ESP module with ESP8266
>>> import network
>>> import urequests
True
>>> Data = r.json()
>>> Data
{'time': {'updated': 'Oct 3, 2018 12:15:00 UTC', 'updatedISO': '2018-10-03T12:15:00+00:00', 'updateduk': 'Oct 3, 2018 at 13:15 BST'}, 'disclaimer': 'This data was produced from the CoinDesk Bitcoin Price Index (USD). Non-USD currency data converted using hourly conversion rate from openexchangerates.org', 'bpi': {'EUR': {'code': 'EUR', 'description': 'Euro', 'rate_float': 5593.94, 'rate': '5,593.9390'}, 'USD': {'code': 'USD', 'description': 'United States Dollar', 'rate_float': 6459.77, 'rate': '6,459.7675'}}}
Regards.
P.D: If you want more info about the console module head over https://github.com/yeyeto2788/MicroPyth ... iptConsole
