Either network or requests module reboot the board
yeyeto2788
Post by yeyeto2788 » Wed Oct 03, 2018 12:17 pm
Hello guys,
I have encounter a problem trying to make a script that just checks the price for bitcoins the code is the following:
from console import Display
import urequests
import json
#import gc
oled = Display()
def ConnectWifi(SSID, pwd):
    Function to connect to WIFI.
    Args:
        SSID: String with the name of the WIFI connection.
        pwd: String with the WiFi password.
    Returns: True if it's connected to wifi
    if not sta_if.isconnected():
        oled.clear(0, 1)
        oled.print_wrapped('Connecting to network...')
        time.sleep(1)
        sta_if.active(True)
        sta_if.connect(SSID, pwd)
        while not sta_if.isconnected():
            pass
def GetTime():
    Get local time from the internet.
    Returns: Nothing
    import ntptime
    ntptime.settime()
    ts = time.localtime()
    year = ts[0]
    Month = ts[1]
    day = ts[2]
    hour = ts[3]
    mins = ts[4]
    dayYear = ts[7]
    ActualTime = "%s/%s/%s %s:%s" % (str(day), str(Month), str(year), str(hour), str(mins))
    return ActualTime
SSID = "SSIDName"
pwd = "SSIDPassword"
    #print("Free out: " + str(gc.mem_free()))
    r = urequests.get("https://api.coindesk.com/v1/bpi/currentprice/EUR.json")
    Data = r.json()
    USD = Data["bpi"]["USD"]["rate_float"]
    EUR = Data["bpi"]["EUR"]["rate_float"]
    Date = Data["time"]["updated"]
    oled.clear(0, 1)
    oled.print_on_line("Price from %s" % Date.split(",")[0], 0)
    oled.print_on_line(str(Date.split(",")[1].lstrip()))
    oled.print_on_line("USD: %s" % str(USD), 2)
    oled.print_on_line("EUR: %s" % str(EUR), 3)
    time.sleep(10)
The problems comes when executing the code:
>>> import bitcoin_price
 ets Jan  8 2013,rst cause:2, boot mode:(3,6)
load 0x40100000, len 31108, room 16
tail 4
chksum 0x28
load 0x3ffe8000, len 1100, room 4
tail 8
chksum 0x4e
load 0x3ffe8450, len 3268, room 0
tail 4
chksum 0x09
csum 0x09
$▒▒|▒▒2rrnc▒▒▒
l▒
B▒ܜ▒▒
▒#l`ll▒▒|▒▒so"▒▒▒ll▒l
#▒▒c䌜▒▒b▒
c▒
▒l{$▒l▒▒|▒▒{ob▒▒▒l▒▒b▒
#▒ܜ▒▒b▒$cl▒▒▒N▒{▒▒o|▒
$ld`b▒▒|r▒l▒n▒▒n▒
d`▒▒{▒l▒$2▒
l ▒▒{▒l▒$
l ▒▒{▒p▒
$l {l▒▒▒c▒▒▒c
▒▒#|lc▒▒b|▒▒▒▒
dlc▒▒o▒2Nn▒▒$n▒▒▒▒$▒ld▒▒▒
$`▒o▒▒▒▒cBl$섏▒
c▒▒▒#l▒#r$rdr▒o▒▒▒
▒2c{#▒▒"▒b▒▒cl▒p▒▒s"
▒"▒▒n▒߀▒c{#▒▒"▒b▒▒cd▒
B▒▒{bl ▒l▒▒▒▒▒rNc▒▒▒▒▒▒
▒c▒
b䌜▒▒|▒▒
#l$cl▒▒lo▒l ▒▒lo▒p{l▒$ܞ|▒2▒▒rn#▒▒▒▒▒▒r▒#▒▒#5 ets_task(40100130, 3, 3fff83ec, 4)
OSError: [Errno 2] ENOENT
MicroPython v1.9.4-8-ga9a3caad0 on 2018-05-11; ESP module with ESP8266
The board automatically reboot and it seems to be coming either from the requests module or the network one, the weird part is that from the REPL the error is not reproduced:
>>> import network
>>> import urequests
True
>>> Data = r.json()
>>> Data
{'time': {'updated': 'Oct 3, 2018 12:15:00 UTC', 'updatedISO': '2018-10-03T12:15:00+00:00', 'updateduk': 'Oct 3, 2018 at 13:15 BST'}, 'disclaimer': 'This data was produced from the CoinDesk Bitcoin Price Index (USD). Non-USD currency data converted using hourly conversion rate from openexchangerates.org', 'bpi': {'EUR': {'code': 'EUR', 'description': 'Euro', 'rate_float': 5593.94, 'rate': '5,593.9390'}, 'USD': {'code': 'USD', 'description': 'United States Dollar', 'rate_float': 6459.77, 'rate': '6,459.7675'}}}
Anyone that could help me out here?
Regards.
P.D: If you want more info about the console module head over https://github.com/yeyeto2788/MicroPyth ... iptConsole
