main.py in programming
for some reason,it error
now main.py maybe in endless loop
in this time it seemed will not restart
how to do
main.py在运行过程中,在循环了几次之后 可能因为各种原因报错退出了
目前看到的就是,退出后不再执行任何程序
那么怎么做呢?让他重新运行起来
when main.py Program error ,how to restart it
Re: when main.py Program error ,how to restart it
When main.py eventually finishes, you can delete or rename it from the REPL
delete: uos.remove("main.py")
rename: uos.rename("main.py", "newname.py")
The board does not need main.py to start. And it is a common practice to put in main.py just an import statement for your bulk code. Besides that, you should in most cases be able to stop a running script with Ctrl-C from the console.
