how to change default ip address in ap mode?
hello everyone I did a search in google to know how to change the default names of the network, ip address and password in ap mode, I only found the name of the network but not the ip and the password, someone knows how to do it? first of all, Thanks.
Re: how to change default ip address in ap mode?
hello again I found the password, I just need to change the ip by default 192.168.4.1, thanks in advance
hi, i have the same problem how to change the default ip address 192.168.4.1 to another one e.g. 192.168.82.66
I believe this is done using ifconfig().
on my esp I have this configuration:
# Complete project details at https://RandomNerdTutorials.com
import usocket as socket
except:
import socket
import dht
import esp
esp.osdebug(None)
import gc
gc.collect()
ssid = 'AP-esp8266_garaz'
password = '123456789'
ap = network.WLAN(network.AP_IF)
ap.active(True)
ap.config(essid=ssid, password=password)
while ap.active() == False:
pass
print('Connection successful')
print(ap.ifconfig())
sensor = dht.DHT11(Pin(14))
# ESP8266 GPIO 5
relay = Pin(5, Pin.OUT)
except:
import socket
import dht
import esp
esp.osdebug(None)
import gc
gc.collect()
ap.active(True)
pass
# ESP8266 GPIO 5
As Christian said, you need to add a call to ifconfig -- this works in both station and AP mode to set the device IP address.
thanks guys for the answer but could you make it clearer ... or some example, please
The documentation that Christian linked to had an example
http://docs.micropython.org/en/latest/l ... N.ifconfig
Put that before or after the line "ap.config(ssid=...)".
