I developing a mobile vibration sensor.
In the first iteration, I was started writing on micropython (NodeMCU platform).
As a vibration sensor, I try used ADXL345 and MPU6050.
My goal is to get real-time information from the accelerometer via Wi-Fi with a frequency of > 800Hz.
But the limit I got now is 200 Hz.
Is it possible to interrogate the sensor with a frequency of 1000 Hz and transmit data via Wi-Fi once a second on ESP8266 or ESP32?
Best regards
High-speed via Wi-FI
Re: High-speed via Wi-FI
You should check using time,ticks_us(), how long each of the steps:
- reading the ADXL345
- reading the MPU6050, and
- sending the data takes.
Then you will know the fastest rate you can get.
Both are good enough for 800Hz.
OUTPUT DATA RATE AND BANDWIDTH User selectable
Measurement Rate3 6.25(min) 3200(max) Hz
OUTPUT DATA RATE
Programmable Range 4(min) 1,000(max) Hz
https://www.sparkfun.com/datasheets/Sen ... DXL345.pdf
https://store.invensense.com/datasheets ... V3%204.pdf- reading the MPU6050, and
OUTPUT DATA RATE
webrepl_client.py https://github.com/Hermann-SW/webrepl#webrepl-shell
upysh_ with wc, od and pipeing https://github.com/Hermann-SW/micropyth ... -statement
That raw sensor information does not tell much. It is just one of the limits. I suggested to determin the actual time it takes to get a value form the sensor on an ESP8266.
[quote=Roberthh post_id=31794 time=1541937658 user_id=601]
[/quote]
I am reading from MPU6050 with preprocessing data. The duration of the measurement along the 3 axes is 20 ms.
Next, I will try to get values of MPU registers and form packets of 1000 bytes and send via UDP
I think I can get the desired speed.
[/quote]
If one measurement takes 20ms, you can perform 50 measurements per second, which does not match with the 200/s, you already got.
