Hi!
I have a Wemos D1 mini that I'm trying to connect to, from my Manjaro Linux machine. I've succesfully installed esptools and `esptool.py --port /dev/ttyUSB0 erase_flash` successfully returns:
esptool.py v2.5.1
Serial port /dev/ttyUSB0
Connecting....
Chip is ESP8266EX
Features: WiFi
MAC: 18:fe:34:db:e9:53
Uploading stub...
Running stub...
Stub running...
Chip erase completed successfully in 27.1s
Hard resetting via RTS pin...
Now flashing micropython on to the Wemos with 'esptool.py --port /dev/ttyUSB0 --baud 115200 write_flash --flash_size=detect 0 /home/ginner/micropython/esp8266-20180511-v1.9.4.bin --verify' returns the following:
esptool.py v2.5.1
Connecting....
Chip is ESP8266EX
Features: WiFi
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 16MB
Flash params set to 0x0090
Compressed 604872 bytes to 394893...
Wrote 604872 bytes (394893 compressed) at 0x00000000 in 34.9 seconds (effective 138.5 kbit/s)...
Hash of data verified.
Leaving...
Verifying just-written flash...
(This option is deprecated, flash contents are now always read back after flashing.)
Verifying 0x93ac8 (604872) bytes @ 0x00000000 in flash against /home/ginner/micropython/esp8266-20180511-v1.9.4.bin...
-- verify OK (digest matched)
After this I try to connect with 'picocom /dev/ttyUSB0 -b 11520' and see this: https://imgur.com/a/U17e9lB
I've tried with different baud rates, '--flash_mode=dout' as I've read somewhere on here, '-fm dio' as I've read elsewhere bu to no avail... I really hope someone is able to help.
Thank you.
[solved]Serial REPL connection not working
Re: Serial REPL connection not working
In the firmware update, you have to set the flash size manually to 4 MB. Try:
See also this post: viewtopic.php?t=3860
Using 16MB requires more changes.
esptool.py -p /dev/ttyUSB0 --baud 115200 write_flash --flash_mode=dio --flash_size=4MB 0 esp8266-20180511-v1.9.4.bin
Wow! That did it! Thank you so much
Re: [solved]Serial REPL connection not working
You need to specify the correct baudrate 115200, then you will see correct REPL.
I just flashed Wemos D1 minis without specifying the flash size, and verify as well as serial console REPL worked fine.
Pico-W Access Point static file webserver:
https://github.com/Hermann-SW/pico-w
Tiny MicroPython robots (the PCB IS the robot platform)
viewtopic.php?f=5&t=11454
webrepl_client.py
https://github.com/Hermann-SW/webrepl#webrepl-shell
webrepl_client.py
