Esp8266 + Mqtt
andrequeiroz
Esp8266 + Mqtt
Post by andrequeiroz » Tue Dec 11, 2018 10:01 pm
One help please. I'm initiating my studies with micropython, I'm using a lang esp8266 board with Mqtt. Everything works fine but if you pass a time interval of 1 min without the esp8266 receiving some message it stops responding to mqtt commands.
--------------------------------------------------Code------------------------------------------------------------------------------------
import ubinascii
import micropython
# Setup a GPIO Pin for output
led = Pin(12, Pin.OUT)
pin = machine.Pin(2, machine.Pin.OUT)
# Modify below section as required
CONFIG = {
# Configuration details of the MQTT broker
"MQTT_BROKER": "iot.eclipse.org",
"USER": "",
"PASSWORD": "",
"PORT": 1883,
"TOPIC": b"micro/python",
# unique identifier of the chip
"CLIENT_ID": b"esp8266_" + ubinascii.hexlify(machine.unique_id())
# Method to act based on message received
def onMessage(topic, msg):
print("Topic: %s, Message: %s" % (topic, msg))
if msg == b"on":
pin.off()
led.on()
elif msg == b"off":
pin.on()
led.off()
def listen():
#Create an instance of MQTTClient
client = MQTTClient(CONFIG['CLIENT_ID'], CONFIG['MQTT_BROKER'], user=CONFIG['USER'], password=CONFIG['PASSWORD'], port=CONFIG['PORT'])
# Attach call back handler to be called on receiving messages
client.set_callback(onMessage)
client.connect()
#client.publish("test", "ESP8266 is Connected")
client.subscribe(CONFIG['TOPIC'])
print("ESP8266 is Connected to %s and subscribed to %s topic" % (CONFIG['MQTT_BROKER'], CONFIG['TOPIC']))
client.wait_msg()
#msg = (client.check_msg())
finally:
#client.disconnect()
listen()
Re: Esp8266 + Mqtt
Post by pythoncoder » Wed Dec 12, 2018 7:14 am
My guess is that the broker has a keep alive time of one minute. Try adapting your code to publish every 30 seconds. I general it's worth using a local broker to learn MQTT before moving to a real web service.
