uPyLoader Will Not Connect with USB and Serial Connection
Posted: Sat Jan 05, 2019 12:08 pm
uPyLoader fails to connect on a LoLin NodeMCU board by wifi or usb cable to PC if RXDO (GPIO3) is attached to modem TX, regardless of modem on/off. [TXD0 (GPIO1) and GND are attached to modem RX and GND respectively.]
uPyLoader connects without problems by usb or wifi if RXD2 (GPIO13), TXD2 (GPIO15) and GND are attached to modem TX, RX and GND respectively.
I need to read modem uart. Is there a way to connect modem to RXD0 or do I need to use different uart serial channels and uos.dupterm? If so how?
Edit: I'll think more about Feedback on uart_swap implementation.
Hmm:
Terminal redirection and duplication
class UART – duplex serial communication bus, methods
Documentation is [s]certainly terse, could use some example code[/s] bloody useless.
Hmm:
