Working with ESP8266 (ESP-07S)
Posted: Fri Jan 11, 2019 7:14 pm
by Dezert
I have noticed this version of the ESP8266 features an IPEX connector for an antenna. I was wondering if it differs in any other ways from other chips and if there are any issues with it or anything else I should know?
Re: Working with ESP8266 (ESP-07S)
Posted: Thu Jan 24, 2019 3:12 am
by mcauser
Should be the same ESP8266EX chip in all of the ESP-xxx modules.
Some are configured with more flash memory.
Some expose additional pins.
Some have a metal can / shielding.
See http://esp8266.net/ for more specifics.
IPEX / U.FL connectors are only rated for a small number of reconnects. Maybe 20-30x reconnections. That's the main concern.
They are also 50 ohms impedance, as with bigger (RP-)SMA connectors.
Short U.FL -> SMA pigtails are fairly common and cheap.
Posted: Thu Oct 17, 2019 2:23 pm
by iamneo2416
Hi Sir,
Receltly, I also got my ESP07S. originally, I used ESP8266-12E with arduino IDE (Node MCU 1.0-12E setting) to do code, burn and test. Everything was fine. Thing wend weird when I switched to ESP07S. I also use arduino with Node 1.0-12E setting to do code and burn, it can be burned without any error. I also follow ESP07S user manual GPIO and write a LED blink via GOIP, it cames out with error and board keep resetting. I check my code. It is really easy without any extra code below.
void setup()
   pinMode(10, OUTPUT); // GPIO-15 ( according to ESP07S user manual, page 6 )
   //  https://www.rfsolutions.co.uk/downloads/1494602250ESP-07S_Datasheet.pdf
void loop()
   delay(1000);
   digitalWrite(10, HIGH);
   delay(1000);
   digitalWrite(10, LOW);
burn this code and ESP07S keep resetting !!
Did I do anything wrong ? Or I need to do some parameter change for NodeMCU 1.0-12E setup ?
Can you help me with this ??
-ryo
Posted: Thu Oct 17, 2019 4:31 pm
by jomas
This is the Micropython forum. Your code is C.
But your problem is that you should use the GPIOxx names as pin and not the physical pins of the board.
