HOWTO: Wifi repeater/Mesh network
roost
Post by roost » Mon Feb 11, 2019 3:30 pm
I am trying to create a Wifi Repeater with an esp8266 (Wemos d1 mini pro) to create a "mesh network" so the other nodes connected to the parent node will have internet access.
Does anyone know how to do this?
I found a github repository which might help. But this is for Arduino.
This is the github repository: https://github.com/martin-ger/esp_wifi_repeater
kevinkk525
Re: HOWTO: Wifi repeater/Mesh network
Post by kevinkk525 » Mon Feb 11, 2019 5:22 pm
The ardunio repository allows for up to 5Mbps only, so I'd assume that creating the same functionality in micropython will be a lot slower and make the Wifi Repeater even less usable.
I can't help with creating this in micropython, I was just wondering about possible applications.
roost
Post by roost » Mon Feb 11, 2019 5:25 pm
I don't need this to be fast. Becouse the only thing i want to do is send commands from one esp8266 to the other. But i want this in a mesh to cover more area.
Zigbee would be a valid option. But i don't want this protocol, becouse this is expensive.
kevinkk525
Post by kevinkk525 » Mon Feb 11, 2019 5:59 pm
You could just use the firmware from the repo on one of your esps and communicate between all other connected esps.
But that's of course just a workaround and not the solution to your question.
roost
Post by roost » Tue Feb 12, 2019 9:38 am
No this is not a solution becouse i want to control lights with the esps. So i kind of want something like Philips Hue, but more extended and with much less of a cost.
kevinkk525
Post by kevinkk525 » Tue Feb 12, 2019 9:44 am
Ok I understand, you want to deploy multiple devices without the need of having one device just as a wireless access point.
roost
Post by roost » Tue Feb 12, 2019 9:52 am
Exactly! I want all of those devices to connect to each other. (Mesh network. just like XBee but then with the ESP8266 module, with wifi.)
